Split wheel rims recommendation please
Postby al pushpak » Sun May 16, 2021 9:22 am
Hi, as above can anyone recommend decent split rims that don't start to rust & end up with flakey paint after 2 months & haven't got studs made of cheese! thanks for any feedback :)
al pushpak
Re: Split wheel rims recommendation please
Postby gaz_powell » Sun May 16, 2021 12:32 pm
I always rated genuine SIL rims, but as they came in primer they always had to be finished. I still have a couple new slight seconds ones, that will powder coat when needed.
I recently needed some chrome rims and used Scootopia ones to get chromed, the SIL I had had a couple of ripples in the pressing so weren't good enough for chrome #
I can't vouch for the longevity of the paint, but everything else was good ( 2 half matched, studs decent, steel thickness/quality etc) and the finish appeared decent.
# counter to that was I first tried BGM show chrome rims.... To quote Paul Calf.. " bag of shite"
If I wanted off the shelf paint finished rims I would use Scootopia again.
Got some MEC Ali ones on the shelf I'm going to try on next tyre change
Postby al pushpak » Sun May 16, 2021 1:10 pm
Hi Gaz, thanks for your reply & info, I'm currently running BGM ones & while the overall finish is good the studs aren't the greatest & the paint soon started to flake, also had scootopia ones & had an issue with valve hole positioning! might give the SIL ones a go ,I will need to paint them so not fussed about the finish. thanks again :)
al pushpak
Postby gaz_powell » Sun May 16, 2021 1:31 pm
Only problem with SIL is getting them now. SR only have seconds, last time I spoke to them they said they were down to very poor ones now.
What about FA Italia, their stuff is generally pretty good?
As you've tried BGM and Scootopia, might be worth a try
I've just got a pair for a vespa small frame I'm doing and the quality is good (they will be powder coated)
Postby al pushpak » Sun May 16, 2021 1:40 pm
OK,thanks for that, may have a look at the FA Italia ones then. Cheers
al pushpak
Postby ULC Soulagent » Sun May 16, 2021 1:47 pm
Best on the market bar none is the bgm stainless steel variant but at a cost, FA Italian are not bad for the price but I’d check them for roundness ( warped) before fitting ur hoop ;)
ULC Soulagent
Postby al pushpak » Sun May 16, 2021 2:09 pm
Cheers guys ;)
al pushpak
Postby Toddy » Sun May 16, 2021 4:07 pm
Scootopia ones are good quality but hard work getting tyres on them :(
Postby gaz_powell » Tue May 18, 2021 9:36 pm
I was pleased with the Scootopia ones I had chromed, they fitted easy with Scootsmart.
A very nice fit was powder coated SIL rims, Mypol tubes and SIP Performer (not Performance) tyres.
Fitted before lockdown last year so untested as yet!
Postby Toddy » Tue May 18, 2021 9:45 pm
gaz_powell wrote:I was pleased with the Scootopia ones I had chromed, they fitted easy with Scootsmart.
Less paint ;)
Postby gaz_powell » Wed May 19, 2021 6:42 pm
No paint!
Postby Toddy » Wed May 19, 2021 7:33 pm
gaz_powell wrote:No paint!
Exactly ;)
Postby citydaz » Wed May 19, 2021 9:18 pm
Toddy wrote:Scootopia ones are good quality but hard work getting tyres on them :(
+1 very hard to get tyres on, but overall very good quality
citydaz
Postby Ballspeed65 » Thu May 20, 2021 7:59 pm
Imola rims from Cam Lam.
Ballspeed65
Postby martyn dwane » Fri May 21, 2021 11:27 am
whatever happened to the split rim tubeless that Pinasco ( i think) were bringing out ?
read about them possibly 18 months ago.
martyn dwane
Postby ULC Soulagent » Sun May 23, 2021 8:05 am
Ballspeed65 wrote:Imola rims from Cam Lam.
Just bought a set along with an alloy type spilt rim from them, I’ll keep you posted ;)
ULC Soulagent
Postby Storkfoot » Sun May 23, 2021 8:38 am
I really like the alloy split rims. They are light and sturdy. They also retain their satin/gloss finish. They do not look like original rims though although I suppose there is nothing to stop you painting them.
Postby Scooterslag » Sun May 23, 2021 11:04 am
martyn dwane wrote:whatever happened to the split rim tubeless that Pinasco ( i think) were bringing out ?
Yeah I was interested in these as well, haven't heard anything since they were announced.
Postby ULC Soulagent » Thu May 27, 2021 2:47 pm
Well the imola rim turned up :? made by Mecur so nothing special about them, tiny bit of unevenness but nothing too worry about. The all alloy rim is impressive( very light) and again a tiny bit of unevenness. Just debating on shall it be a front or rear fitment
ULC Soulagent
Postby gaz_powell » Fri May 28, 2021 8:01 pm
I've got 3pr of the MEC Ali splits, they look decent. Just not got round to fitting them up or on anything...
It's on the later base....
Users browsing this forum: No registered users and 9 guests
