Hydraulic front disc brake
Postby Revvers » Wed Apr 28, 2021 3:09 pm
Apologies if this has been covered before. I’m looking at adding an hydraulic front disc brake to my Li Special S3. I’ve watched a couple of You Tube videos (!!) and it looks reasonably straightforward. Am I wrong? Is it do able for a very average home mechanic, or would I be better off getting it professionally fitted??
I’m concerned about drilling the headset and the bleeding, so any tips/advice welcome. Thanks
Revvers
Re: Hydraulic front disc brake
Postby missing lynx » Wed Apr 28, 2021 3:37 pm
It's a straight forward job. The only problem is most of the hose supplied with the kits are in my opinion too short. Routing the hose can be tricky but and I always cut a slot in the headset bottom for the hose to sit in as it means you don't need a big hole to accommodate the nut on the end of the hose. As for bleeding make sure you cover any paint work and wear gloves as it will pickle your paint and can cause cancer. As for the bleeding prosses I would go on YouTube it would be easier than trying to explain, but it is very simple
Postby Revvers » Wed Apr 28, 2021 8:00 pm
Thanks. Will it be ok to drill the top of the headset rather than the bottom? I’m thinking if I don’t like it, welding the top headset will be more straightforward than the bottom
Revvers
Postby missing lynx » Wed Apr 28, 2021 10:46 pm
Yes should be fine but it does depend what angle you can get the connection on the master cylinder at
Postby Warkton Tornado No.1 » Thu Apr 29, 2021 12:27 am
Revvers wrote:Thanks. Will it be ok to drill the top of the headset rather than the bottom? I’m thinking if I don’t like it, welding the top headset will be more straightforward than the bottom
Slotting the headset bottom offers offers advantages of being neater as the top hides the slot ends but it does weaken it. Therefore the disadvantage of slotting the 'bars' is that they are weakened & easier to snap, even with a low speed tumble.
The neatest way of routing the hose is down through the fork tube (if you can handle the dismantling of the superior braided type) to enable feeding the bare hose through the fork bottom holes (Oooer!)
Postby Meds » Thu Apr 29, 2021 5:30 am
Bleeding can be frustrating a get on your nerves - a good method- patience and perseverance will work
I use a big syringe and fill it gently from the bottom - then bleed it - ( plenty YouTube videos)
There is another alternative - semi hydraulic where a cable operated the master cylinder is hidden behind the horn cast
Or the Leg shields.
I have one - with careful bleeding and cable adjustment it works fine.
It does Take bit of effort -It get to keep the original headset look
Google Vespa Grimeca semi hydraulic
Meds
Postby Revvers » Thu Apr 29, 2021 4:43 pm
Thanks for the tips guys. I’m going to give it a go.
Revvers
Postby hullygully » Thu Apr 29, 2021 5:04 pm
there's the other option of under the leggies bud too
Postby Binny » Fri Apr 30, 2021 1:31 pm
If you use the type of hydraulic hose that you can dismantle/make up yourself then you can feed the hose back into lever mounting/housing so that it follows the route of a standard cable in the headset and down to the front hub. Doing this way means no visible drilling of the headset and only a couple of inches of exposed hose at the headset between the master cylinder banjo and where it loops back into the lever/cylinder housing. I think it was Jason Frost who came up with this very neat method of routing the hose.
Binny
Postby Storkfoot » Tue Jan 18, 2022 11:58 pm
Users browsing this forum: Google [Bot] and 98 guests
