EGT gauges and fitting
Postby peejay » Wed Oct 29, 2014 10:20 am
hi peeps
would some of you guys post pics of what you are using and how you have mounted the gauge and installed the plumbing.
ta very much :D
Re: EGT gauges and fitting
Postby mainstand » Wed Oct 29, 2014 4:30 pm
My EGT gauge is going to be mounted in the top of my new inside legshield toolbox, Cables tied underneath the frame & brought up behind the horncast, then a small hole drilled in the legshield & the wiring brought through.
mainstand
Postby foremanbob » Thu Oct 30, 2014 9:25 am
mainstand wrote:My EGT gauge is going to be mounted in the top of my new inside legshield toolbox, Cables tied underneath the frame & brought up behind the horncast, then a small hole drilled in the legshield & the wiring brought through.
I used the same technique for plumbing.... mounted in different ways on my GP and S2, and different guages.
GP using a standard instrument pod....
S2 mounted on a home made bracket to top horncast screw....
foremanbob
Postby PSC GP200 » Thu Oct 30, 2014 9:46 am
Hi,
I was thinking of fitting one to engine. What are the best types, prices and availability and where to buy from etc.
Many thanks.
PSC GP200
Postby jonashford » Thu Oct 30, 2014 1:49 pm
jonashford
Postby PSC GP200 » Thu Oct 30, 2014 6:47 pm
Thanks.
Looks like I'll get the RT 1000. Is that most people use?
PSC GP200
Postby peejay » Thu Oct 30, 2014 7:30 pm
thanks guys for all the info so far :)
Postby peejay » Wed Nov 05, 2014 10:29 am
hi guys
has anyone got pics of fitting and routing details of the sensor from the exhaust pipe just to give me some idea what to do, ta :)
Users browsing this forum: Bing [Bot] and 5 guests
