Dellorto PHBH BD (Right Hand Adjustment)
Postby AlG » Mon Mar 08, 2021 5:06 pm
I have a GT240 running a 30mm PHBH BS on the drive/KS side, so adjustment on the left against the engine mounting and really difficult to get to.
There is loads of space on the other side, so a PHBH BD (D for destra, or right) makes sense, except they only seem to come up as four Stroke carbs off MotoGuzzi's.
Has anyone found a BD two stroke, or converted a four stroke to two stroke? How easy is it, what parts are needed for the conversion?
AlG
AlG
Re: Dellorto PHBH BD (Right Hand Adjustment)
Postby gaz_powell » Mon Mar 08, 2021 8:56 pm
I had the same problem with a TS1, so just blanked it off and set tick over near enough on the cable, then used the
adjuster on top to get it perfect.
You can get RH 2 stroke ones I've got one on another bike but it's a bit older, they are definitely not as readily available as the LH
Postby martyn dwane » Mon Mar 08, 2021 10:30 pm
/www.dellorto.co.uk/shop/dellorto-motorcycle-carburettors-parts/carburettor-parts/phbephb-parts/9198-atomiser-bush-for-phbh/
this is what you need
martyn dwane
Postby AlG » Tue Mar 09, 2021 2:32 pm
Cheers Dwayne, Looks like it is cheaper to buy a new one from Dellorto UK than find and convert a second hand Guzzi carb.
AlG
Postby ROClarke » Wed Mar 10, 2021 7:15 pm
I fitted a BGM air screw on mine and shortens it so I could adjust the mixture.
ROClarke
Postby hullygully » Fri Mar 19, 2021 5:19 pm
easy enough to knock the 4 stroke atomisor holder out
done it to 2 dellys upto date
if you need some info I can scan it in for you?
Users browsing this forum: Bing [Bot] and 10 guests
