by Fairburn » Thu Feb 18, 2021 10:17 am
Having a special bush pulling tool made up to draw the large brass bush out of its recess for replacement. Can anyone give me the outside/inside diameters in order to locate the tool correctly.
Fairburn
by jbcollier » Fri Feb 19, 2021 5:44 pm
Don't have a D/LD apart right now to give you the dimensions. Just order the replacement bushing and that'll give you the dimensions you are after.
jbcollier
Return to Pre 57
