Mec crank
Mec crank
Postby PSC GP200 » Wed Oct 29, 2014 1:30 pm
Hi guys,
I am currently running a cast stage 4 200 barrel with 30mm delly and NK road pipe with a 58mm Mec 'race' crank. My question is will the crank be able to cope with a race rapido 225 barrel used with the same carb etc?
Cheeres, Nick
PSC GP200
Re: Mec crank
Postby Wack » Wed Oct 29, 2014 8:22 pm
Yes, several mates run that crank in TS1's no problem.
Re: Mec crank
Postby PSC GP200 » Thu Oct 30, 2014 9:40 am
Thanks for that.
To go off original topic, but can anyone post what carb settings they would use to suit the cast 200?
Currently using 120 main, 55 pilot, x7 2nd clip, 17 btdc, remote ram air, 40 slide.
PSC GP200
Re: Mec crank
Postby corrado » Thu Oct 30, 2014 2:57 pm
Current carb set up sounds in the ball park with an AV266 atomiser. May want to change the standard float valve from 200 to something bigger 250/270/300. Bit like a fast flow tap there's no real down side to fitting one.
corrado
