Warkton Tornado No.1 wrote:the switches can be rebuilt without replacement, unless they are externally broken. Brake light switches are so simple to rebuild with so few consumable parts that the hardest element to fix is a worn plastic housing that can have a bespoke part to cure the slack pin hole or be plastic welded & redriled to suit.
Warkton Tornado No.1 wrote:Ignition, though? Is there any justifiable reason to go electronic on a 'preserved' machine? FFS nobody can claim that the Indian replacements are bought for reliability!
That is why, if anything, I would maintain points but would upgrade the voltage to 12 volt. That was a commonplace conversion in the period that the machine was first used.
Storkfoot wrote:I am no electrician but, in my experience, a six pole system is significantly more robust than a 4 pole which are hard work. Incidentally, I have a good six pole stator and flywheel which I know were working when they came off the 125 Special many years ago - yours if you want them.
Storkfoot wrote:Switches. I have successfully saved one or two but too often it is the rocker mechanism that is worn out and beyond saving. I’d suggest, if they look okay, try them but be prepared to buy new if there are any issues.
Storkfoot wrote:Finally, Carlos at Swiss Tony’s does have some good stuff and is definitely worth making contact with.
Knowledge wrote:Hi,
I have acquired an early (May 62) TV175 which I intend to preserve.
It has the early style headlamp.
ToBoldlyGo wrote:
How does the headlight differ? I wasn't aware there was a difference.
Knowledge wrote:TBG,
Please can you confirm thar the four pole TV173 SIII’s had half moon ignition switches, or their own version of the four pole switch without a half moon?
Sorry, I’m getting a bit pedantic now.
Users browsing this forum: Google [Bot] and 129 guests
