Danbretta wrote:Any tips on removing a stubborn chaincase. I've tried pulling the clutch arm to help pop the case of with the clutch pressure to no avail.
Any of you guys know of a better technique.
Seems the gasket sealant is doing a good job at holding the case on. Just thought I'd ask before I get heavy handed with it.
My only thought is to run a bit of gasket sealant remover around the edge and hope that soaks down enough to relieve the adhesion.
Any tips.
Thanks in advance.
bookertmgs1 wrote:Are you sure that you havent got a bent stud that is binding on the side case?
Danbretta wrote:Hopefully this is a common failure and I'm not going to find more issues to the cause of this roller splitting.
What's a decent chain to go for? Are there ones to avoid?
Toddy wrote:Danbretta wrote:Hopefully this is a common failure and I'm not going to find more issues to the cause of this roller splitting.
IWIS are a good chain
Users browsing this forum: No registered users and 87 guests
