Brake Pads
Brake Pads
Postby rossclark » Tue Aug 11, 2020 10:29 pm
Sticky's manual mentions organic compound brake pads instead of the standard / sintered ones for the NIssin calipers.
Does anyone know a part number or what sort pads they are to search for?
Re: Brake Pads
Postby rossclark » Fri Aug 14, 2020 9:10 pm
No-one?
Let's try another tack - anyone know what the caliper is OEM for?
Re: Brake Pads
Postby Wack » Fri Aug 14, 2020 10:51 pm
Pretty sure these are the ones you need https://www.ebay.co.uk/itm/Kyoto-Brake- ... SwU7JeAifr or https://www.amazon.co.uk/AHL-Front-Brak ... NrPXRydWU= The original Nissin part number is 4K03P
Re: Brake Pads
Postby rossclark » Sat Aug 15, 2020 12:00 am
Thanks Wack - closer to understanding what to look for. ;)
Re: Brake Pads
Postby rossclark » Sun Aug 23, 2020 12:30 am
For anyone following this.
The pads are Size:77.3x42.2x7.2mm
If you want some organic ones the right size these fit
Re: Brake Pads
Postby martyn dwane » Tue Apr 29, 2025 7:56 am
Anyone know what bike the OEM used ,I need a service kit for mine ,seals and pistons.
martyn dwane
Re: Brake Pads
Postby Scooterslag » Tue Apr 29, 2025 9:44 am
martyn dwane wrote:Anyone know what bike the OEM used ,I need a service kit for mine ,seals and pistons.
I think its a Honda NS125- cheers Paul :)
Re: Brake Pads
Postby martyn dwane » Tue Apr 29, 2025 11:20 am
thanks Paul.
martyn dwane
Re: Brake Pads
Postby martyn dwane » Thu May 01, 2025 11:11 am
Any one know the piston size ? Martin @ just Lambretta list a full kit but is out of stock.
desperate to get this back before Tik`s remembrance ride next week .
martyn dwane
