s3 bossatta rear light
Postby garynonnah » Sun Oct 19, 2014 11:09 am
being stupid.....but not sure where to connect earth wire???
I know pink and black connect to left & right teminals....but not sure if one in middle is earth???
garynonnah
Re: s3 bossatta rear light
Postby Captain Pugwash » Sun Oct 19, 2014 1:26 pm
Middle connector pointing up should be an earth.
Captain Pugwash
Postby garynonnah » Sun Oct 19, 2014 10:28 pm
thanks fella....what i thought, but then doubt set in...
garynonnah
Postby Knowledge » Mon Oct 20, 2014 12:57 pm
Try fitting a bulb in the fitting before you fit it to the scooter, and check that the two prongs make a good contact with the pins on the bottom off bulb. Sometimes, the prongs can even touch each other, creating a short ciruit.
It's easy to check now, but not so easy to check when the housing is fitted to the scooter.
Postby garynonnah » Mon Oct 20, 2014 6:39 pm
thanks for that.. :D
garynonnah
Postby lammydave » Mon Oct 20, 2014 6:44 pm
not being funny, but i struggled to find a decent rear light for my GP.... the bulb holder are mostly rubbish...
I ended up cutting out the supplied bulb holder, and enlarging the hole to take a standard series 3 reflector...works much better
lammydave
Users browsing this forum: nsaints and 10 guests
