LD jumping out /off first gear and also difficult to select?
Postby LambrettaJourney » Fri May 08, 2020 5:43 pm
Hi All,
Italian Teleflex LD Pre 55.
Any ideas on why a pre 55 (Teleflex cable) LD would be jumping out / off first gear?
It is also difficult to select gear?
Any ideas gratefully received on what I might be able to look at / into?
Thanks in advance.............
LambrettaJourney
Re: LD jumping out /off first gear and also difficult to sel
Postby jbcollier » Sun May 10, 2020 3:46 pm
Gearbox sections from,
The Book of the Lambretta Scooter:
https://jbcollier.smugmug.com/Scooter/i-Tx47zzs/A
https://jbcollier.smugmug.com/Scooter/i-qV24rvV/A
https://jbcollier.smugmug.com/Scooter/i-NP8bHGD/A
The Lambretta Serviceman's Book:
https://jbcollier.smugmug.com/Scooter/i-6SFTjgX/A
https://jbcollier.smugmug.com/Scooter/i-zCBmDBF/A
https://jbcollier.smugmug.com/Scooter/i-3WCZFfW/A
https://jbcollier.smugmug.com/Scooter/i-vsPp3JF/A
Instructions are for the twin cable shifter but everything else is mostly the same. If the gear has been popping out for a long time then the engagement dogs can wear such that they will always pop out. If that is the case, replacement is best. However, you can carefully grind the dogs square again if they are not too bad AFTER you have fixed the engagement issue.
jbcollier
Postby LambrettaJourney » Sun May 17, 2020 12:02 pm
Hi jbcollier.
Thanks for getting back to me and providing the images, as well as ideas on what to look for. Posted on behalf of someone else. If he gets back to me, I will confirm what was done to rectify the problem. All the best and have a good day..............
LambrettaJourney
Return to Pre 57
Users browsing this forum: Baidu [Spider] and 2 guests
