Headset wiring
Headset wiring
Postby Mick1499 » Wed May 06, 2020 9:38 pm
Okay, please help, this is doing my head in. LI headset wiring can anyone explain how to wire it up? The bulb holder looks like it’s made by Fisher-Price, I have taped together (temporarily) the wires I think go together and have posted pics of what wires I have. I have done a full rebuild and this is by far the worst bit without doubt.
Mick1499
Re: Headset wiring
Postby rossclark » Thu May 07, 2020 12:46 am
Do you have the Sticky Manual? All the wiring diagrams are in there.
You'll need to give a bit more information.
What Series Li?
Italian or Spanish or Indian?
AC or DC? Do you have a battery?
Key switch or kill button?
What switch on the throttle side?
Have you replaced the loom?
If so is it standard or simplified?
General comments -
You will have wires from the loom usually -
Green - engine kill that shorts the ignition to earth either via the kill button or keyswitch - usually via a pink wire which goes to one of the screws on the gear or throttle rod supports.
Brown, purple and grey - these are usually live feeds and usually matched to corresponding colours from the switch(es)
Black - usually the is connected to the speedo bulb and to the tail light
the handle bar switch will usually have -
Red/ Blue - power to the dip and main beam - it doesn't matter which is which.
Yellow - power to the side light bulb.
Brown / purple / grey power into the switch
white to horn - pressing the button completes the circuit to earth.
HTH
Re: Headset wiring
Postby rossclark » Thu May 07, 2020 12:48 am
BTW - if you replace the loom / switches with new from various sources there is no guarantee the colour coding is maintained as per OEM
Re: Headset wiring
Postby Mick1499 » Thu May 07, 2020 9:20 am
Thanks for that Italian series 3 but electronic ignition .new switch so yeah not all colours don’t match wiring diagram .
Think sticky manual is next try ?
Mick1499
Re: Headset wiring
Postby Mick1499 » Thu May 07, 2020 10:04 am
One last thing what edition is best for my needs 3 ?
Mick1499
Re: Headset wiring
Postby ULC Soulagent » Thu May 07, 2020 5:58 pm
Mick1499 wrote:One last thing what edition is best for my needs 3 ?
The latest one 3rd edition
ULC Soulagent
Re: Headset wiring
Postby Agent Orange » Thu May 07, 2020 6:33 pm
The Sticky manual makes this a doddle. New loom around £30 and worth the investment on a rebuild.
Agent Orange
Re: Headset wiring
Postby missing lynx » Thu May 07, 2020 7:24 pm
Hi the top pic looks like an s2 light back an s3 one should have terminals for all the wires look at page 140 in sticky's book third edition
Re: Headset wiring
Postby St George » Thu May 07, 2020 9:46 pm
If you need any pic's photographed in Sticky's book 3, I can Whatsapp them.
St George
Re: Headset wiring
Postby Mick1499 » Thu May 07, 2020 11:03 pm
I have ordered sticky’s book today from ebay . I need something that says the wire from point A is plugs into point B if that makes sense
Mick1499
Re: Headset wiring
Postby missing lynx » Fri May 08, 2020 10:45 am
Mick1499 wrote:I have ordered sticky’s book today from ebay . I need something that says the wire from point A is plugs into point B if that makes sense
Sticky's book has a comprehensive section of wiring diagrams in the back but you will need to order a new bulb holder/connector block as the one you've pictured is an S2 one not an s3
Re: Headset wiring
Postby rossclark » Sat May 09, 2020 12:12 am
On the a to b thing a multimeter with beep mode is invaluable in working out where things start and end and in tracing eart faults.
Users browsing this forum: Bing [Bot] and 6 guests
