shamrockexpress wrote:is there any reason not to use original italian ones?
rossclark wrote:shamrockexpress wrote:is there any reason not to use original italian ones?
Yes
They're minimum 50 years old and who knows what abuse they've had over the years.
photo sharing
ToBoldlyGo wrote:Yes, the thicker one on the left is generally used in the S2. Whereas the one on the right is a standard S3. But there is no guarantee that the earlier one wasn't used in later models. So it's just rule of thumb.
shamrockexpress wrote:cant argue with that,,,,,,,,,innocenti paper weights lol
Warkton Tornado No.1 wrote:shamrockexpress wrote:is there any reason not to use original italian ones?
This issue of "New versus Old" has been raised before & TBH, & it's fair to say no decisive action has been taken to address the concerns within the debate.
It amounts to "New (but uncertified materials, manufacturing methods, quality processes/inspection & transportation/storage care)" versus "Old [in the case of OEM] (but no means of quantifying age related stresses)"
As far as I am aware (& I stand to be corrected) those OEM layshafts that have failed have had assumptions made as to the reason why. It's all very well to speculate why a layshaft can fail, but I would argue that it cannot be put down to age. Otherwise, WW2 aircraft & the like would never be allowed to fly.
That said, virtually all old planes & Motorsport vehicles will have to conform to some kind of worthiness certification, right down to each safety critical component.
'We' (as a large owner enthusiast club) do not apply those principles adopted by other organisations, & I personally would prefer it if we did.
I'm not looking to add fuel to any argument, but this is an emotive subject.
I believe there is an amount of naivety in both camps.
If it were feasible to source an absolutely unused NOS (New Old Stock) layshaft & compare it with one of the pattern/'upgraded' replicas in testing (destructive if need be) then the results would be able to speak for themselves.
Until then, any evidence is largely anecdotal.
I hope nobody believe that I am out to p*ss on their chips, but surely many of us have by now been caught out with the presumption of "new being better?"
It is a fact of life that copies are rarely as good as the originals, with very few exceptions.
It's not just layshafts that need to be thought about, though some replacement components are more obviously a safety issue to some of us. For instance. Layshaft bearings with ball-cages that are 'popped in' during construction can so very easily 'pop out' again. Premium rear shock absorbers have been dangerous. Heavy duty disc brake cables have failed. Tubeless rims have been proven unsafe.
Even rear hubs can fail, including NOS OEM 'Innocenti' hubs that collapse, as has happened to many of us during the rigours of racing. That's why Serveta rear hubs are prized, but even the OEM Innocenti hubs are designed to 'fail safely', that is, collapse inwardly toward the gearbox, rather than outwardly. Still a b@stard to control, mind you, then push back to the pits. Do you know just how safe your modern pattern rear hub is? It may not have failed, but if it does, do you have the assurance that it will fail as it should? I don't care how many have been sold & are in use. That's not proof of fitness for purpose.
Scooterdude wrote:Warkton Tornado No.1 wrote:shamrockexpress wrote:is there any reason not to use original italian ones?
I suppose that in my case my big saving grace would be if the original layshaft failed whilst out I’m basically up the creek without a paddle, on the other hand however if my new AF one was to fail I would fully expect full recompense from AF not only to cover the layshaft but also other damage caused to the scooter as a result of their product failing.
dscscotty wrote:If nothing else, at least a new one will not have had 50yrs of abuse, and been under severe stress due to being over the recommended torque settings, despite whats been relayed I've seen 40+bhp put through new type layshafts, under very hard circuit racing and endurance racing and not had a failure in 5yrs, for me thats enough.
Users browsing this forum: Baidu [Spider], Nudger and 83 guests
