AF Clo5e ‘box - 5th gear exchange
Postby Knowledge » Sun Apr 12, 2020 3:32 pm
Hi. I have the AF five speed box fitted and love it, but I now think I should have gone for the longer 5th gear. Before I fork out £110 for the alternative cog from the supplier, I wondered if anyone had bought the longer 5th gear and with hindsight would have preferred the shorter cog.
Would anyone fancy a swap?
Re: AF Clo5e ‘box - 5th gear exchange
Postby Dibs/SFSC » Sun Apr 12, 2020 4:59 pm
I have used the taller 34T fifth cog on my Rapido 250 and must admit it was the correct decision, gives me around 4:61 final drive which was perfect for Poland last year and pulls nice and strong. Reason I went for 34T in lieu of 35T was final drive ratio for 35T was around 4:71 which was not far from the 4;8 had with the four speed.
Dibs/SFSC
Postby bike grim » Sun Apr 12, 2020 6:44 pm
Knowledge wrote:Hi. I have the AF five speed box fitted and love it, but I now think I should have gone for the longer 5th gear. Before I fork out £110 for the alternative cog from the supplier, I wondered if anyone had bought the longer 5th gear and with hindsight would have preferred the shorter cog.
I haven’t but wondered: What final drive does the 35 give you?
Postby hullygully » Tue Apr 14, 2020 12:45 pm
Dibs, that's what I settled for on my Broady 5-speed, perfecto 8-)
Postby Knowledge » Fri Apr 17, 2020 12:39 pm
Hi Gerry,
I have finally got the Tony Cassidy visualiser in front of me and I can see the effect on the final drive ratio of changing from 35 to the longer 34 fifth gear.
On my 20 x 46 sprockets, the final drive ratio would drop from 4.24 (35j to 4.12 (34). The fourth gear to fifth gear jump will change from 9% to 12%.
You can bump the 34 tooth fifth gear final drive ratio ack up to 4.21 by swapping the sprockets for 20x 47.
Any one up for a swap?
Postby Scooterlam » Sun Apr 26, 2020 3:30 pm
So tempted,
I've the reverse
Sell me yours.
Scooterlam
Postby Knowledge » Mon Apr 27, 2020 10:29 pm
You’ve got a reverse gear! Wow.
Postby Tractorman » Tue Apr 28, 2020 10:01 am
Knowledge wrote:You’ve got a reverse gear! Wow.
Be useful for the combo :)
Postby Dicky » Sun May 03, 2020 12:56 pm
I fitted 35 to mine and regretting it. ( not regretting the purchase though it’s nice to ride but tops out too soon) Running 18/47 on a Rapido with 60 stroke crank and reed valve but not a revvy pipe (TSR Evo). Seems I got my sums wrong! Looking to fit 34 but given the low % rise of the box I’m wondering whether to just puta a 19 on the front (need a cog, chain and pull down tensioner or possibly 19/46. The cog would be cheaper though but more of a pain if I just want to suck it and see!
Dicky
Postby Dibs/SFSC » Sun May 03, 2020 6:15 pm
Dicky wrote:I fitted 35 to mine and regretting it. ( not regretting the purchase though it’s nice to ride but tops out too soon) Running 18/47 on a Rapido with 60 stroke crank and reed valve but not a revvy pipe (TSR Evo). Seems I got my sums wrong! Looking to fit 34 but given the low % rise of the box I’m wondering whether to just puta a 19 on the front (need a cog, chain and pull down tensioner or possibly 19/46. The cog would be cheaper though but more of a pain if I just want to suck it and see!
I have the same set up 18/47 Rapido 250 with the 34 tooth and must admit although a small % rise (need to be careful of going too tall) it is a joy to ride, 4th is perfect for those slight inclines and head winds and 5th on the straight is no struggle at all
Dibs/SFSC
Postby Dicky » Mon May 04, 2020 10:47 pm
Helpful ta. Think that’s probably the way to go!
Dicky
