Hat wrote:I’d try working from the plug back; cap, ht lead, cdi before going for the stator. Does it still rev when its spluttering or will it not go at all?
MickYork wrote:check flow rate from tank
check breather hole in cap
might be worth stripping carb and checking float moves freely
change stator
CHRIS in MARGATE wrote:You know what it is.... it's the stator. Classic fault.
Granty wrote:Hat wrote:I’d try working from the plug back; cap, ht lead, cdi before going for the stator. Does it still rev when its spluttering or will it not go at all?
I've replaced the plug, cap, HT lead, only the cdi & stator to goYes it still revs through the splutter and goes in a fashion but just spluttering & not revving through as it should. As I've said I've been up and down with the clip on the needle, if I move it to the bottom it just bogs down as it should do if too rich -- this spluttering is different.
Thanks for taking the time to reply -- G
St George wrote:Let us know which stator you chose, so many out there. I had a brand new one in storage for ages, when it was fitted, same issues as yours.
St George wrote:Also make sure that you have a good earth on engine to frame. Regards.
CHRIS in MARGATE wrote:You will find that it will still fire with that earth missing with electronic ignition.
rossclark wrote:CHRIS in MARGATE wrote:You will find that it will still fire with that earth missing with electronic ignition.
If the white from the stator is connected to the CDI and that is in turn earthed
St George wrote:Which model BGM Stator did you get please. Glad it's sorted.
Users browsing this forum: Google [Bot], Vinnyvegas and 66 guests
