electrical advice
Re: electrical advice
Postby Fast n Furious » Sun Mar 01, 2020 7:11 pm
Postby rossclark » Sun Mar 01, 2020 11:53 pm
Interestingly I fitted mine the other day in a weather gap. Switching the power feed on the DC feed doesn't stop it sparking. I presume that this is because there is juice in the circuit when you turn it over, as I know the way mine is wired the regulator feeds into the circuits even if the battery isolator is in the off position - some things still work.
Next time it's dry enough I'm going to try the green - red kill mechanism as I need to be able to switch it off...
Postby Fast n Furious » Mon Mar 02, 2020 11:20 pm
rossclark wrote:Interestingly I fitted mine the other day in a weather gap. Switching the power feed on the DC feed doesn't stop it sparking. I presume that this is because there is juice in the circuit when you turn it over, as I know the way mine is wired the regulator feeds into the circuits even if the battery isolator is in the off position - some things still work.
This is the correct way to do it with all ignitions that don't use the stator's LT coil.
The alternative way is to use a different ignition switch from a donor motorbike which can be hard to find.
