Which Clubman have I got.
Postby St George » Fri Feb 14, 2020 6:06 pm
Came with a project I bought last year, looks to be 42mm, it has a rod welded from the back of the silencer to the tail pipe. Otherwise looks like any other clubman with no markings on it. U Pipe, one piece normal fitting. Thanks
St George
Re: Which Clubman have I got.
Postby ToBoldlyGo » Fri Feb 14, 2020 9:58 pm
Not much to go on. Could be a Sito Ancillotti perhaps.
ToBoldlyGo
Postby HxPaul » Sat Feb 15, 2020 10:09 am
If it has a two piece downpipe it could be a scootopia copy of an Ancilotti.
Postby St George » Sat Feb 15, 2020 4:01 pm
One piece pipe. Internal of pipe 35 mm, external 40 mm. Can't post pictures sorry.
St George
Postby Toddy » Sat Feb 15, 2020 4:17 pm
St George wrote:One piece pipe. Internal of pipe 35 mm, external 40 mm. Can't post pictures sorry.
If you want to e mail pics to me I can post for you paul.todd2@yahoo.co.uk
Postby vegansydney » Sat Feb 15, 2020 8:26 pm
As noted above due the strengthening bracket it could be anything from a Sito Ancilottii (TS/Evergreen), an RS Clubman or a even a homemade addition to another Clubman. Please post some photos.
vegansydney
Postby ToBoldlyGo » Sat Feb 15, 2020 11:33 pm
If you are the one that posted on FB I can tell you that it looks like an Indian big bore exhaust.
ToBoldlyGo
Postby St George » Sun Feb 16, 2020 4:11 pm
Pics sent to Toddy so everyone can see. Thanks for replies.
St George
Postby Toddy » Sun Feb 16, 2020 8:59 pm
There you go buddy
Postby ToBoldlyGo » Mon Feb 17, 2020 9:06 pm
Indian big bore. Rough as a bears arse.
ToBoldlyGo
Postby al pushpak » Tue Feb 18, 2020 8:24 am
"Indian big bore. Rough as a bears arse" But perform a lot better than most of the more expensive club mans available out there ! :D ;)
al pushpak
Postby St George » Tue Feb 18, 2020 10:11 am
Thanks lads, it does sound nice. Job done.
St George
Postby vegansydney » Wed Feb 19, 2020 4:22 am
If you plan on fitting it, I'd spend 10 minutes blending the U-bend where it mounts on the exhaust port with a Dremmel (or similar tool). This will aid the flow of exhaust gases.
I'm surprised you can't see sunlight through it :lol: That said, it looks no better than all the Casa U-bends (S3/GP/dl) I've seen :shock:
vegansydney
Postby St George » Wed Feb 19, 2020 5:52 pm
Thanks, the other side of the flange is nicely welded. Can fill the gaps with exhaust putty. Cheers.
St George
