Casatronic Timing / Strobe Gun Issue?
Postby nsaints » Sat Feb 15, 2020 11:32 am
Sanity check required :?
I have watched the Casa video how to fit and time my casatronic ignition
I have marked my mag housing at 24 and 16 degrees BTDC, with the expectation at fast tickover I set the timing to 24, and then as revs rising the firing point advances to 16
I'm also aware with this ignition there are two sparks per revolution, 180 degrees apart
At fast tick-over my strobe indicates the mark on the flywheel correctly in relation to the 24 degree mark on the mag housing
However as revs rise, instead of the flywheel mark advancing towards 16, it completely vanishes !
The marking at 180 firing point remains visible at all times - the engine sounds clean still (indicating it must still be firing between 24/16 BTDC
anyone else seen this issue
This must mean my strobe is knackered - would you agree?
nsaints
Re: Casatronic Timing / Strobe Gun Issue?
Postby CHRIS in MARGATE » Sat Feb 15, 2020 12:45 pm
It retards, not advances. Is your clamp on your strobe directional? Weird and alarming if timing mark disappears ! It must be somewhere.
Postby nsaints » Sat Feb 15, 2020 1:48 pm
yep, sorry
Drove and got my mates strobe gun, no issues using his
Mine must be faulty and only flashing on one signal through the HT
nsaints
Users browsing this forum: No registered users and 193 guests
