Honing Tool
Honing Tool
Postby NorthernJordan » Thu Oct 09, 2014 6:26 pm
Does anyone have any experience in using a honing tool? Will I need a bench drill? Or can I just use a hand drill?
NorthernJordan
Re: Honing Tool
Postby dscscotty » Thu Oct 09, 2014 7:30 pm
What type of honing tool do you have?
Re: Honing Tool
Postby gaz_powell » Thu Oct 09, 2014 8:19 pm
I have a three legged glaze buster that you put varying grades of stones on the legs
it attaches to a drill - when I have use it I just use a cordless
if it one of these use it cautiously and just give it a few runs up and down to rough the surface
Re: Honing Tool
Postby dave411 » Thu Oct 09, 2014 8:27 pm
use it on a very slow speed,and I mean slow.Move it up and down the bore as you go.I also run it in reverse,and use a thin oil,2 stroke is fine.
dave411
Re: Honing Tool
Postby dave411 » Thu Oct 09, 2014 8:28 pm
your cordless drill will be fine.
dave411
Re: Honing Tool
Postby dscscotty » Thu Oct 09, 2014 9:37 pm
Glaze busters are ok but are not a proper hone, as already stated run it at a slow but constant/consistent speed, be careful cos they can oval the bore, I use hydraulic fluid to lube the bore. Or you could get one of these to do the job proper? http://usatoolsinc.com/ProductImages/lisle/LIS15000.jpg
Re: Honing Tool
Postby NorthernJordan » Fri Oct 10, 2014 10:53 am
I haven't bought one, but was wondering what was needed to do a decent job?
The flexi hones are fine to use with just a cordless without perfectly aligning the barrel?
At my work we have bench drill, milling machine and laithe. Are these of any use?
NorthernJordan
Re: Honing Tool
Postby dave411 » Fri Oct 10, 2014 4:33 pm
yeah,milling machine will sort it :lol: :lol:
dave411
Users browsing this forum: No registered users and 3 guests
