missing lynx wrote:Have you asked SIP? I just do mine as tight as I can with the socket bar I carry in my tool kit
Hat wrote:14lbft is recommended. there's no need to over tighten using the nordlocks on soft alloy
Warkton Tornado No.1 wrote:Hat wrote:14lbft is recommended. there's no need to over tighten using the nordlocks on soft alloy[/Wherever the source for that recommendation came from, does it relate to standard OEM hub studs & nuts, or SIP specifically?
I think caution should be taken into account with the reproduced hub studs & nuts, unless they have a grading shown.
The cheaper (A2) stainless nuts, for example in the instance of the OEM set up may be only Grade 6 or less. Replacement OEM type hub studs may be anybody's guess as far as Grade.
It's great to be consistent in applying a torque, but the quality of the fasteners must be taken into account & as to whether the fasteners are assembled 'dry' or 'lubricated'
(I have witnessed ridden scooters with sheared studs, stripped (loose) nuts because the rider only cared about bling & trying to impress his mates with whatever suspension, front brake etc he had with no concern for the safety of others. Whenever I come across such horrors, I feel duty bound to correct such liabilities prior to testing/release of the bike. Inevitably, it's a thankless/unpaid task......)
Next time you are at a rally looking over other scoots, take a look at the variations in front wheel alignment. The amount that are not in the middle of the forks is alarming.
coaster wrote:Warkton Tornado No.1 wrote:Hat wrote:14lbft is recommended. there's no need to over tighten using the nordlocks on soft alloy[/Wherever the source for that recommendation came from, does it relate to standard OEM hub studs & nuts, or SIP specifically?
Another issue with Nordloc washers is that the torque required to get the washer to 'ratchet' up as the 2 parts slide up over the ramps plays havoc with the torque setting
gizmo wrote:Maybe better with MB's method. Plain washer and spring washer.
Warkton Tornado No.1 wrote:I don't like having to rely on those washers & the nuts supplied are humungous.
On the SIP rims I have fitted, I use M8 K-nuts which have never come loose on anything.
Users browsing this forum: Google [Bot], Vinnyvegas and 49 guests
