standard 200 PHBL 25 High Temps half throttle
Postby Bilko » Wed Jan 08, 2020 10:05 pm
Bit of a conundrum.
I'm running in a standard 200 with 25 PHBL With hose and filter and a Scootopia Ancillotti pipe.
Timing 18 Dregrees
Currently trying...
AQ266
D24
50 pilot
102 Main Jet
2.50 Float Valve
2nd clip down it runs fine all the way through, but if I hold at half throttle the temperature soars over 650C. (The thumb choke helps bring the temp down).
So I moved the needle clip down and it gets boggier 3/4 throttle and the temperature at half throttle still soars
I was checking carb settings and I noticed some have an AQ268 with a D22 needle. I would have thought that the leaner needle with a shorter taper wouldn't help my half throttle issue. Or have I got it wrong?
I have an AQ268 on order (I ordered one a couple of weeks before Christmas, but I've lost it). I have a selection of needles, the ones being used by most are D22/D24/D26.
Some of you will remember that I've got some sort of half throttle curse with pretty much every engine I use. (Except my TS1).
So, I'd like some opinions and education on setting up the carb.
Bilko
Re: standard 200 PHBL 25 High Temps half throttle
Postby Tractorman » Thu Jan 09, 2020 10:19 am
When I had the same engine set up the carb settings were
main 102
needle D29 1.5
atomiser AQ270
pilot 48
slide 45
Postby Bilko » Thu Jan 09, 2020 11:08 am
Thanks.
Bilko
Postby ULC Soulagent » Thu Jan 09, 2020 12:02 pm
Rt200 reedvalve
Choke 60
Idle 50 screw set at 1.45 outs
Slide 45
Atomiser aq 266
Needle D22
Main 110
With filter ;)
ULC Soulagent
Postby martyn dwane » Thu Jan 09, 2020 3:26 pm
Im running a rapido 225 with LTH reed and BGM V3 clubman, i was ruuning aq 266 but had a slight seize going up a long (but not really steep) hillaround half throttle, was advised to go up to AQ268 but stay with same needle , maybe drop it down one,
Now running
main 118
needle D29 2.0
atomiser AQ268
pilo51
slide 40
martyn dwane
Postby Bilko » Thu Jan 16, 2020 1:53 pm
Now moved to AQ268 and D22 which helped a lot, but I still get this high-temperature mid throttle, although it does rise slower than before. Half throttle and up is ok, but leading to half throttle is getting too rich, so I can't raise the needle.
Bilko
Postby ULC Soulagent » Thu Jan 16, 2020 2:36 pm
Try a different exhaust Robert too rule out heat bleed ;)
ULC Soulagent
Postby Cgt75b » Fri Jan 17, 2020 5:09 pm
Have you tried a D29 needle I would if I was you.
I would be inclined to run a 300 float needle valve also, just my tuppence of course.
Good luck with the black art of jetting
Cgt75b.
Postby Bilko » Sun Jan 19, 2020 2:21 pm
ULC Soulagent wrote:Try a different exhaust Robert too rule out heat bleed ;)
Put different exhaust on, but didn't make a difference Shane
Bilko
Postby Bilko » Sun Jan 19, 2020 2:24 pm
Cgt75b wrote:Have you tried a D29 needle I would if I was you.
Cgt75b.
I will now thank you.
Bilko
Postby ULC Soulagent » Tue Feb 04, 2020 1:41 pm
How u getting on with this issue Robert?
ULC Soulagent
Postby Bilko » Wed Feb 05, 2020 8:26 pm
I've been riding it without changing anything yet Shane. Hopefully tomorrow, but I haven't got an EGT at the moment, but should have next week.
Bilko
Postby ULC Soulagent » Wed Feb 05, 2020 9:41 pm
Sound ;)
ULC Soulagent
Postby HxPaul » Thu Feb 06, 2020 9:56 am
Bilko wrote:Bit of a conundrum.
Timing 18 Dregrees
Currently trying...
AQ266
D24
50 pilot
102 Main Jet
2.50 Float Valve
I have a Casa 210(same as a casa 185,but for a big bore case)I use a PHBL 25 with a clubman exhaust system.
m.J.98
Pilot.J.50
AQ 268 atomiser
D29 needle on second clip down.
Slide 40
Choke 60
Runs ok,a bit rich on the bottom end but thats the way I like it(safe)
Postby Bilko » Thu Feb 06, 2020 9:46 pm
Cheers Paul.
Bilko
Return to Carburettors
