Reedspeed ts1 manifold
Postby steve chapman » Sun Oct 13, 2019 6:55 pm
Has anyone else had a problem sealing up a reedspeed ts1 manifold, tried 2 x gasket sealants and it just wont seal , one problem is it only has 3 fixings instead of the 4 on a stud ts manifold , Steve
steve chapman
Re: Reedspeed ts1 manifold
Postby Toddy » Thu Oct 24, 2019 6:14 am
Did you get sorted Steve ? where was it leaking from ?
Postby steve chapman » Sun Oct 27, 2019 7:58 pm
No Toddy I didn't , ended up putting the std ts1 one back on ,
It was leaking at the front where the fourth fixing should be , cant see why they only used three fixings as there is plenty room , Steve
steve chapman
Postby Wack » Wed Nov 06, 2019 7:11 pm
I’ve had the same so ended up fitting an M5 stud as the nut is easier to tighten
Postby carlos fandango » Mon Nov 11, 2019 9:55 pm
Strange , mine has 4 fixing point as per std TS
carlos fandango
Postby Fast n Furious » Tue Nov 12, 2019 1:07 am
LTH manifolds are 3 point fixing if I remember rightly.
Really crap, especially if used with packer plates.
Don't do it.
That 4th fixing, although a pain, is a must.
Users browsing this forum: Majestic-12 [Bot] and 4 guests
