PM Tuning Apr 1984 - Barrel and Head
Postby Roey99 » Thu Aug 15, 2019 3:30 pm
Hi.
I've discovered an interesting barrel and head at the bottom of a box of bits that came with an old scooter.
It looks to me like a standard iron barrel that has been tuned, the engraving says " PM Tuned - Apr 84 - SP"
The exhaust port looks about 42mm and a standard big bore gasket seems to fit well.
The inlet port has stud centres about 64mm
The barrel is aprox 66mm bore.
It will need a clean and at least a hone, there aren't any ridges or lips to remove it just looks a bit rusty.
Which inlet manifold would work best if I wanted to use a non reed valve set up - or is it tuned for a reed valve ?
The head seems to be matched and has a rather interesting message etched into the under side - heaven only knows why this was added !
Worth keeping and fitting ? or put it back in the box ?
Thanks for your help - jr
Roey99
Re: PM Tuning Apr 1984 - Barrel and Head
Postby Roey99 » Thu Aug 15, 2019 3:32 pm
Another couple of photos :-)
Roey99
Postby Cgt75b » Sun Aug 18, 2019 10:50 am
That’s some inlet!
Postby dickie » Sun Aug 18, 2019 7:50 pm
I'd go out of my way to sell it to someone from Scotland. :D
Users browsing this forum: Bing [Bot] and 5 guests
