Stalling
Stalling
Postby Geocamper » Sat Jul 20, 2019 7:31 pm
Out on a spin recently and my lambretta cut out. It started back up on one kick and carried on riding until I got home when again the lambretta cut out. Sounded like it was bogging down then cut out. I thought maybe the idle jet had a bit of crud stuck in it but when I checked it looked clean. I blew the idle jet out just in case and also cleaned the bowl out which was clean anyway. Everything looks ok inside the carb(phbh 28). When I start the lambretta it sounds fine through the power range with no loss of power. Running a RT195. Im at a loss to this issue. Any help would be appreciated.
Geocamper
Re: Stalling
Postby MickYork » Sat Jul 20, 2019 8:13 pm
Petrol cap breather blocked ?
Re: Stalling
Postby Storkfoot » Sat Jul 20, 2019 8:53 pm
Have you checked for an air leak at exhaust manifold or cylinder head, in particular?
Re: Stalling
Postby Tony Hart » Sat Jul 20, 2019 9:31 pm
Could be a split carb rubber. As it starts to split you can get your symptom of not idling properly.
Tony Hart
Re: Stalling
Postby Fast n Furious » Sun Jul 21, 2019 10:00 pm
Could also be a sign of imminent LT stator coil failure.
Re: Stalling
Postby GRTDKAD » Sun Aug 15, 2021 12:50 am
** Thread resurrection **
Similar issues with my TS1, starts and goes okay, but when out and about it will look to stall at junctions and traffic lights. So I need to sit and rev like a teenager to keep it going.
Seems to be searching, struggling to just tick over.
Out earlier I stopped in a local town - as I pulled up in the lay-by it stalled. I was there for about 10 mins (as planned) but when I went to restart it took about 20-30 kicks to get going again. Sometimes it’ll take one kick then other times it’ll take a bunch and be a PitA.
It’s a bit spluttery at lower speed but pulls like a train once in the power band.
TS1 230
35mm Mikuni
Franspeed Tourer
Plug: just changed from a Champion N3 (was a bit oily but chocolate brown) to a Denso W24ES
Runs on Super Unleaded
I have a new HT Lead and Cap and CDI here in my spares. Worth starting with these?
Any suggestions where to start greatly appreciated.
GRTDKAD
Re: Stalling
Postby MickYork » Sun Aug 15, 2021 7:24 am
What's your carb' set up ?........could be too rich at low rev's (choke sticking ?)
Re: Stalling
Postby GRTDKAD » Sun Aug 15, 2021 9:40 pm
Thanks Mick. Good point, I’m going to have to check…
GRTDKAD
Re: Stalling
Postby GRTDKAD » Mon Aug 16, 2021 4:46 pm
Looks like it was the air screw all along. Setting was just a tad optimistic - now changed to 1+3/4
Sits and ticks over nicely with panels off / on so hopefully okay. Will need a good run around the town to test.
Thanks !
GRTDKAD
Users browsing this forum: Bing [Bot], fredste, steveg and 14 guests
