Rear mudguard fitment.
Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
Postby Storkfoot » Fri Jun 28, 2019 9:05 pm
I know they fit via self tapping screws. But, the holes I have on the frame are massive.
I assume, therefore, that they are C clips (is that what they are called?) tothe frame to allow you to fit them. Am I right, or wide of the mark? :)
Re: Rear mudguard figment.
Postby trotsky » Sat Jun 29, 2019 10:05 am
Hi Paul,
Hope your well. No it is a crude self tapper fixing - end of production cut backs I guess :( . Personally I would try using a Rivnut type set-up, but that will leave a shoulder on the outside so the mudguard will not quite be flush to the frame, or as I did just tack weld a nut on the inside. Hope this helps, Steve.
trotsky
Postby Storkfoot » Sat Jun 29, 2019 5:31 pm
Thanks, Steve. Rivnuts, yes of course. I have some somewhere, just haven’t used them in a few years.
I am good thanks. Regards to Wendy. Hope to see you soon, mate.
Re: Rear mudguard fitment.
Postby Storkfoot » Sat Jul 06, 2019 1:13 pm
Thanks again, Steve. Rivnuts worked well.
Postby trotsky » Sun Jul 07, 2019 1:34 pm
Marvlus job bud. :)
trotsky
Postby coaster » Sun Jul 07, 2019 1:43 pm
Is that a GRP mudguard Paul? needs a pan head screw and washer to spread the load ;)
Postby Storkfoot » Sun Jul 07, 2019 2:58 pm
coaster wrote:Is that a GRP mudguard Paul? needs a pan head screw and washer to spread the load ;)
These screws were the nearest M4s to hand ;)
How’s your Vega coming along?
Return to Luna & J Range
