AF double row hub bearing help required
Postby Bidsy » Fri Jun 28, 2019 11:11 pm
Just got one of the new AF double row hub bearing to go with my AF clo5e, I notice the bearing has a seal in both ends, do you need to remove the internal one to allow the bearing to be lubricated.
Can’t seem to get through to AF Rayspeed to ask them.
Bidsy
Re: AF double row hub bearing help required
Postby Fast n Furious » Sat Jun 29, 2019 12:18 am
This bearing has a double Labryinthe seal. No need to mess with it.
Just make sure that your gearbox breather plug is free breathing.
Postby Knowledge » Sat Jun 29, 2019 3:11 am
I have run one for a short period with both seals intact, and it has been fine.
Much less friction than the usual garter seal.
Postby gunnerdaz » Fri Aug 02, 2019 10:13 pm
I've just bought one of these. So no lubrication needed.
gunnerdaz
Postby Knowledge » Sat Aug 03, 2019 10:11 pm
Correct. Keep both seals in place.
Postby Norrie Bodge » Sun Oct 27, 2024 7:41 pm
Old thread I know 8-)
Using one of these bearing in a new build engine
Has anyone had any issues with any failures?
Rear brake was canny but not crap
“ this is a full new engine build with breather pipe type used & an extra one added using a drilled m6 stud & pipe fitted on one of the gear pivot posts “
Havent inspected yet but I’m expecting oil on brake shoes :oops:
Norrie Bodge
Postby Norrie Bodge » Thu Nov 07, 2024 10:38 am
Norrie Bodge wrote:Old thread I know 8-)
Yep as I thought FFS
Can these type bearings oil seal be replaced?? Just phoned AF & phone lines are down all week :oops:
Norrie Bodge
Users browsing this forum: nsaints and 6 guests
