Solid Air wrote:Just a straight forward one Andy, greased so that it doesn't stick and can be reused if careful. Don't think the cork seal as well as modern types but I've found the silicone comes off the new style in bits so only really good for one use.
Mel K wrote:The silicon used on the BGM ones disintegrates once it comes into contact with the engine oil , this happens while on the bench even before use . So will probably cause no end of leaks once running. Save yourself money and time and don’t use them .
Users browsing this forum: Bing [Bot] and 7 guests
