Throttle Cable Change
Postby Granty » Mon May 06, 2019 10:32 pm
Changing my set up, swapping a standard jetex for a dellorto PHBH, on the traditional side - RHS looking at the bike. Do I need to change the throttle cable to an extra long one & then re-route as a matter of course? Cheers G
Granty
Re: Throttle Cable Change
Postby Tractorman » Tue May 07, 2019 7:38 am
Not if you get a 90 degree bend, you will need a new inner because it's longer on the PHBH and the solder less nipple is at the headset end.
Postby missing lynx » Tue May 07, 2019 7:37 pm
Also if you drill the throttle wheel so the cable can pass through the solderless nip and the throttle wheel it makes it much easier to fit the cable
Return to Carburettors
Users browsing this forum: No registered users and 15 guests
