nylon/plastic cage drive side
Postby lam1962brettagg » Fri Apr 26, 2019 2:21 pm
just about to fit a koyo drive side r2s. took one seal off to find it is plastic/nylon caged??
just wondered what the general concensus is about this. all other main bearings i've fitted have been metal caged.
standard s3 li150 casa new crank.
also, c3 or cm rating if a nylon caged is ok to fit?
cheers in advance.
lam1962brettagg
Re: nylon/plastic cage drive side
Postby ULC Soulagent » Fri Apr 26, 2019 3:11 pm
:? I wouldn’t fit it if it was mine, only seen and used metal cage ;)
ULC Soulagent
Postby lam1962brettagg » Fri Apr 26, 2019 7:05 pm
thats what i thought.
nylon cage supplied to me by reputable company wtf.
at the time was unaware because it was a 6305 2rs cm. only when one side seal removed i found it was nylon caged.
lam1962brettagg
Postby Knowledge » Sat Apr 27, 2019 7:23 am
Does the nylon-caged drive side bearings have an extra ball in them?
Postby lam1962brettagg » Sat Apr 27, 2019 8:33 am
Knowledge wrote:Does the nylon-caged drive side bearings have an extra ball in them?
never counted them in the past. not sure really but will let you know if it matters.
can,t really see that it does. they looked as evenly spaced as a metal caged bearing.
fact is its a nylon cage which i dont have much faith in regardless of make.
just had a new koyo delivered metal cage no seals 6305 c3
both metal and nylon cages have 8 bearings.
lam1962brettagg
Postby Warkton Tornado No.1 » Mon Apr 29, 2019 2:11 pm
lam1962brettagg wrote:just about to fit a koyo drive side r2s. took one seal off to find it is plastic/nylon caged??
cheers in advance.
A good European or Japanese bearing with 'rolling elements' that utilises cages moulded from mon-metallic cages can be used within the crankshaft support journals without issue. I have fitted many of them, generally on the magneto side, without issue. In fact, the rating of such bearings is often greater because they allow more 'crowding' of the bearing . That is, more balls or rollers can be designed in.
Kart engines that are loaded & rev significantly higher than Lambrettas utilise phenolic resin cages in preference to metallic cages.
The issue with moulded cages is where safety is an important factor.
I have removed newly fitted rear hub bearings with black, soft nylon cages from the layshaft because they fail, despite the manufacturer having the word "INNOCENTI" etched on to them. I am unsure of the copy rights in claiming such remanufactured products are "INNOCENTI" but I suppose one blessing will be that the actual manufacturer is well known to many of us by another name, & the inevitable investigation when one of those causes a serious accident makes it much more difficult for them to deny liability.
Postby lam1962brettagg » Mon Apr 29, 2019 3:33 pm
cheers in advance.
thanks for the indepth info.
i'm really asking about crank bearings and never had an issue with rear wheel/layshaft bearing. but certainly one to watch out for thanks.
cant something be done about substandard parts/manufactures??
or does someone need to be badly injured or worse first?
cheers
lam1962brettagg
Postby neily03 » Mon Apr 29, 2019 4:36 pm
Sticky's book does say plastic caged bearings are preferable to metal ones for the drive side of the crank. Though I've just fitted a metal caged one myself.
neily03
Postby lam1962brettagg » Mon Apr 29, 2019 7:13 pm
neily03 wrote:Sticky's book does say plastic caged bearings are preferable to metal ones for the drive side of the crank. Though I've just fitted a metal caged one myself.
thanks for that. hadn't read that bit myself so i'll take a look. fitted a metal cage one now too anyway.
cheers
lam1962brettagg
Postby dscscotty » Tue Apr 30, 2019 7:48 am
Used koyo nylon cages several times, without issue, in both road and race motors.
Postby lam1962brettagg » Wed May 01, 2019 2:12 pm
cheers
stickys book also tells us that there are 'ratings' for drive side oil seals too, but digging around and asking various bearing/seal suppliers there does not seem to be such a thing. the single number on the seal is merely a 'mold' number.
I would appreciated any further input on this matter though.
lam1962brettagg
Postby Danbretta » Fri May 10, 2019 10:15 pm
Any reason why the nylon cages are preferable? I'm hoping to fit a bearing onto the crank tomorrow and have a choice of both koyo metal caged and skf nylon caged German made. Any advice?
Thanks.
Danbretta
Postby Warkton Tornado No.1 » Fri May 10, 2019 10:44 pm
Danbretta wrote:Any reason why the nylon cages are preferable? I'm hoping to fit a bearing onto the crank tomorrow and have a choice of both koyo metal caged and skf nylon caged German made. Any advice?
Thanks.
Users browsing this forum: No registered users and 67 guests
