dellorto 28mm phbh
dellorto 28mm phbh
Postby al pushpak » Sat Jun 07, 2014 9:29 am
Hi just wondered if a carb that I have just looked at which is a dellorto 28mm phbh (aprila rs 125,cagiva mito according to the description ) would be OK to use on mugello 200 kit, its marked phbh 28 followed by the letters FD, mixture & idle screws are on the opposite side to most phbh carbs. Thanks for any info al ;)
al pushpak
Re: dellorto 28mm phbh
Postby Rich Oswald » Sat Jun 07, 2014 11:18 am
The usual letters on a phbh carb are BR or BS which means the adjustments are on either the right or left hand side. I don't know what FD means but I would certainly make sure it isn't a 4 stroke version before you use it. I am sure they cam be converted though if it is.
Postby al pushpak » Sat Jun 07, 2014 11:40 am
OK rich thanks for that, will probably give it a miss then. cheers al ;)
al pushpak
Return to Carburettors
