Mikuni TMX30 cable adjusters
Postby bike grim » Mon Apr 01, 2019 7:51 pm
I’m using the above carb on a Quattrini which is running great but the adjuster for the throttle and choke cables are very narrow (6mm I think) and I don’t seem to be able to find anything big enough to fit a normal lambretta cable on line. Anyone recommend anything that will fit?
Re: Mikuni TMX30 cable adjusters
Postby Norrie Bodge » Mon Apr 01, 2019 9:22 pm
bike grim wrote:I’m using the above carb on a Quattrini which is running great but the adjuster for the throttle and choke cables are very narrow (6mm I think) and I don’t seem to be able to find anything big enough to fit a normal lambretta cable on line. Anyone recommend anything that will fit?
Look here m8 - http://www.allensperformance.co.uk/shop/
Norrie Bodge
Postby Solid Air » Mon Apr 01, 2019 11:12 pm
BG let me know if you don't have any luck tomorrow finding the right one.
I have a spare thin one with 6.0mm ID for cable or I could swap with the one on my PWK which has ID for cable of about 7.5mm, failing that Solid Air is on the dyno tomorrow night and I can see if my mate has one knocking about his workshop.
Just send me a message
Mark
Postby bike grim » Thu Apr 04, 2019 9:15 am
Thanks for the help. I’d already looked at Allen’s but note it’s difficult using their descriptions to decide which is the correct type. I’ll give them a call.
Postby Warkton Tornado No.1 » Thu Apr 04, 2019 11:46 am
If you can identify the thread (M5 x 0.8 is common, but so is M6 x 0.75) then that will narrow the search.
There are a lot of components from bikes that will fit anything on a Lambretta or even, if desperate, there are cable adjusters on V*spas these days. When did they stop using rods, I wonder..... :?
Dell'Orto adjusters fit PWK etc & they have the advantage of a very good rubber boot.
Return to Carburettors
Users browsing this forum: No registered users and 2 guests
