Exhaust recommendations
Postby sid boggle » Tue Mar 26, 2019 12:03 pm
I’m currently running a chiselspeed ads3 wich is great other than it hangs low underneath the scooter & has scraped a few times any other exhaust same performance with better clearance any recommendations
sid boggle
Re: Exhaust recommendations
Postby Scooterdude » Tue Mar 26, 2019 1:55 pm
I have one of these on mine and its not to bad on ground clearance to be fair, however I could gain a lot more if i needed to by cutting two small fillets out of the bend under the engine, raising it and tig welding it back together.
This might be an option if you like the way the pipe performs rather than splashing out on a new pipe.
Scooterdude
Postby sid boggle » Wed Mar 27, 2019 9:17 am
It’s more when I’m 2 up on it to be fair thanks for advice I like the pipe so just be more careful in future over sleeping policemen
sid boggle
Postby bike grim » Wed Mar 27, 2019 10:02 am
Assuming you have the correct length rear shock, see if you can take a bit off the actual exhaust stub and move the whole thing upwards. Also, look at the Casa offset cone and bar kit. You can actually alter how the engine hangs in the frame by turning the bar through 360 degrees. It may give you a bit more room but can’t say for sure.
Postby Scooterdude » Wed Mar 27, 2019 10:53 am
Another thought and really cheap. Get a pait of the MB double length fork spring stops these will raise the whole scooter up slightly overall and give a stiffer ride so maybe just what you need.
Scooterdude
