TV 175/200 Series 3
Strict no chatter
TV 175/200 Series 3
Postby Paul Slack » Thu May 15, 2014 5:27 pm
Please note the anoraks corner designed to achieve attention to detail of facts including the history of the model, information maybe used for the main website, so your help and posts will go on to help others. By posting you agree to letting the LCGB use this information for its web site.
Please discuss detail for any Model TV 175/200 Series 3.
Paul Slack
Re: TV 175/200 Series 3
Postby rexton270s » Thu Jul 31, 2014 2:51 pm
i have a very late 1965 tv175 frame number starts with 550, engine starts with 530 it seam like theres alot of differance in the numbers! but after a few convos with other tv riders they could be orginal from the factor as at the time the production was going to spain and the tv was made in batches ? :?:
rexton270s
Postby pacemaker » Fri Aug 01, 2014 11:39 am
You can never say never with Lambretta but that bigger difference I would say it is unlikely to be the original engine.
pacemaker
Postby rexton270s » Fri Aug 01, 2014 4:39 pm
thanks pacemaker,rimini lambretta had a tv175 a few years ago with 545 frame and 520 engine gen scoot from a collecter in italy! but av seen numbers a few hundred different??? :|
rexton270s
Postby charliefentonsboy » Wed Aug 20, 2014 9:11 pm
What style of white buttoned horn/dip switch is on the TV175 III..............like SX, TV200 or TV175 II ?............ and do they differ between pre and post mod?
charliefentonsboy
Postby Dimitrios_231 » Thu Aug 21, 2014 12:00 pm
Just for reference.
These buttons are from a Becme TV S2 (I might clean them one day :) ).
If you have Sticky's book,he has a photo with all the S3 light switches.
Dimitrios_231
Postby Dimitrios_231 » Thu Aug 21, 2014 4:54 pm
This is a G.P.M. Milano switch.
Problem is that I cannot remember if I removed it from a GT or a TV175 :?
Dimitrios_231
Postby charliefentonsboy » Fri Aug 22, 2014 2:33 pm
Dimitrios,
That is my problem, I have both, but not sure if the TV175 II switch transitioned onto the early (pre mod) TV175 III models.
Maybe all TV 3 (175 & 200) models had the same style switch?
charliefentonsboy
Postby Dimitrios_231 » Fri Aug 22, 2014 3:14 pm
According to Sticky's book,early TV175 S3 were using the same switch as TV S2.
The other type,was used on later models (Both 175 and 200).
Dimitrios_231
Postby Dimitrios_231 » Fri Aug 22, 2014 3:48 pm
This is the SX200 switch with white buttons,
it has fewer ridges than the one used on TV models,
the majority of the remade (if not all) looks like the SX type.
Dimitrios_231
Postby Dimitrios_231 » Thu Sep 18, 2014 9:07 am
This one is an early OSAM switch.
Dimitrios_231
Postby george » Fri Sep 19, 2014 2:25 pm
this is the type switch i have on my tv200
george
Postby lambrettatastic » Sat Sep 27, 2014 12:55 pm
I have a 62 tv 175...its early,so has the two fixings at the end of the rear running board strip...does anyone have any of these??? my scooter is 100 % original and one has broken.
lambrettatastic
Postby Andyf » Thu Oct 02, 2014 6:22 pm
wow! knew nothing about that! this Forum never ceases to amaze and enthral, could we (I) see a pic please?
Andyf
Postby lambrettatastic » Fri Oct 03, 2014 7:35 pm
Andyf wrote:wow! knew nothing about that! this Forum never ceases to amaze and enthral, could we (I) see a pic please?
there a few little things about an early tv175...non of which i knew about until i read vittorios book..and did a comparison ... black tank straps,small piece of metal holding the side panel retaining clip in place,small 2.5 speedo cable,...etc. will get some pics up soon.this is a very original,un touched scooter.
lambrettatastic
Postby Digger » Sat Oct 04, 2014 4:48 am
Mine has the small piece of metal holding the side panel retaining clip in place - bloody silly idea as makes wheel changing very awkward. I've bent it to allow the clips to rotate. :shock:
Digger
Postby tim_mason » Tue Oct 28, 2014 5:38 pm
Has anybody got an idea when the transition was of the LI and special style sidepanels was , Month / year ?
tim_mason
Postby Dimitrios_231 » Tue Oct 28, 2014 7:06 pm
December 63,according to Tessera's book.
Dimitrios_231
Postby GeneM » Wed Oct 29, 2014 1:34 pm
charliefentonsboy wrote:What style of white buttoned horn/dip switch is on the TV175 III..............like SX, TV200 or TV175 II ?............ and do they differ between pre and post mod?
although this is a TV200, as they were built in batches along with the TV175 they would have had items like switches in common..
VIN on this is 5414xx
GeneM
Postby GeneM » Wed Oct 29, 2014 1:43 pm
early version of TV175 S3 shown on brochure from May 1962 showing "Special" panels, but no disc brake and what appears to be no rear flash.
My theory is that the disc brake was approved for production just before launch of the S3 and Innocenti opted to include it, rather than the Special panels to keep the announced price the same.
As TV2 and TV3 links are the same, it brings up the thought were Innocenti working on the disc brake for the S2 but had not perfected it yet?
from the pre-mod parts book:
GeneM
Return to Anorak's Corner
