TV 175 Series 3 cylinder
Strict no chatter
Postby Bren » Tue Sep 07, 2021 2:33 pm
Hi all,
After information on S3 TV157 cylinder identification. I purchased my TV 175 many years ago and it came with the original case (empty) and a load of bits, including a cylinder. Over the years its all gotten mixed up with other barrels lying around in the shed and garage. Question is how to identify a genuine 1963 TV175 cylinder? I am acutely aware that the one I originally received with the job lot may have been genuine.
Any information form the experts would be appreciated
Bren
Bren
Re: TV 175 Series 3 cylinder
Postby Storkfoot » Tue Sep 07, 2021 6:57 pm
A TV175 barrel is 80mm between 3rd and 4th fins.
I am unsure whether this is especially helpful as it may well be the case that a 175 conversion barrel is the same. But, it’s a start :)
Postby vegansydney » Tue Sep 07, 2021 11:58 pm
At a glance, the size of the inlet port will be noticeably larger compared to an LI 125 or 150.
vegansydney
Postby Fast n Furious » Wed Sep 08, 2021 12:36 am
I'm pretty sure that only the TV175 cylinder no. 19711020 measured 80mm dia across the main casting and all 150's measured around 70mm.
Return to Anorak's Corner
Users browsing this forum: No registered users and 24 guests
