Tv200 engine number
Strict no chatter
Tv200 engine number
Postby CRICKY » Fri Jul 26, 2019 8:10 pm
Is engine number 553*** a 1965 tv200 thanks for any help
CRICKY
Re: Tv200 engine number
Postby Rich Oswald » Sat Jul 27, 2019 7:54 am
It is if it has a prefix of:- TV/2*553*** (without any CC before the TV prefix). It is difficult to work out exact build dates on TV3's as 175's and 200's were run together in the same sequence.
Postby CRICKY » Sat Jul 27, 2019 7:58 pm
Thanks Rich been a big help
CRICKY
Postby paul lester » Sat Nov 07, 2020 1:36 pm
Hi i have copy of an old logbook for 65 and its a 551 engine number my 65 tv is 547 frame and engine different is 49 numbers
paul lester
Postby TV200MET » Sat Nov 07, 2020 9:48 pm
Hi,
My tv200 that I purchased secondhand back in 1968, that I still have, was first registered April 1964.
I still have the original old green log book.
Engine number starts 533 and frame starts 531.
Hope this helps.
Unfortunately during my earlier years riding lambrettas I damamaged the casing
and being very nieve did not think I could get casing repaired so scrapped it.
Was using a small bore case until replacing with an original tv2 large bore case
with engine no starting 533, so engine and frame number are even closer
TV200MET
Return to Anorak's Corner
