Li 125/150 Special
Strict no chatter
Re: Li 125/150 Special
Postby johnnyXS » Tue May 26, 2015 12:42 pm
I thought it might be useful to post a few identification images to check originality and help with sourcing correct original parts for restoration purposes.
There seems to be lots of posts and some confusion about the correct light/horn switches for the various Li Special models .
This is the switch that came fitted to my Italian import 1964 Special 150 which I have assumed is the original pattern unless someone knows otherwise ?
I assume there are diffences between the switches for early 64/65 Specials and the later 66 on silver specials ? and also for the 150 Golden specials ?
It would be really helpful if owners could post a picture of their switches together with the year, 125 or 150 and whether italian Indian Spanish etc
johnnyXS
Postby Wack » Tue May 26, 2015 9:38 pm
1965 ,150 Silver Special, chrome ring Italian import Image
Postby johnnyXS » Tue May 26, 2015 10:48 pm
wow thats a lot different to mine wack thanks for posting:shock:
I saw a switch like yours on the bay this week advertised as a 150 special and thought it must be a Spanish or Indian version.
I'm beginning to wonder if my switch is correct for 64 ? :?
johnnyXS
Postby sherpadean » Thu May 28, 2015 7:27 pm
Hi Johnny - this is the light/horn switch from my recently imported 1966 Li 125 Special......
sherpadean
Postby johnnyXS » Thu May 28, 2015 7:36 pm
that is different again ?! :shock:
Mine rocker switch has 17x lines your 66 version has 13 I think .
I wonder how many different types there were on the 150 special
Thanks for posting sherpadean cheers ;)
johnnyXS
Postby Hoody » Wed Jun 03, 2015 10:02 pm
[url=http://s304.photobucket.com/user/robert_hood1/media/Mobile%20Uploads/20150601_200039_zps31h24fhz.jpg.html]Image[/u]
150 special 1964 italian import
Hoody
Postby johnnyXS » Wed Jun 03, 2015 11:00 pm
thanks Hoody ....your shot confirms my switch is also the original pattern for a 64 special.
They are so incredibly rare and sought -after that I'm thinking of fitting a modern copy in case someone nicks it of my scoot. :roll:
johnnyXS
Postby Adam_Winstone » Sat Nov 28, 2015 6:30 pm
For those of you on FB, this is a nice example of an LI150S and check out that mudguard...
https://www.facebook.com/12994781045830 ... =3&theater
Postby sherpadean » Wed Dec 02, 2015 10:56 am
Just out of curiosity can anyone tell me the compression ratio for a standard 1966 - 125 Special....?
sherpadean
Postby johnnyXS » Wed Dec 02, 2015 3:42 pm
johnnyXS
Postby sherpadean » Wed Dec 02, 2015 3:48 pm
Thanks Johnny
sherpadean
Postby Adam_Winstone » Fri Feb 05, 2016 6:51 pm
Continuing on the topic of white painted mounts being fitted as standard, I've recently been shown a fantastic example of an original early LI150S and that does have white mounts. If anyone can be bothered to post via web host, let me know and I'll forward you the photos... or even if you just want to have a look, send me your email address by PM and I'll email the photos.
Interestingly, the FB discussion was followed by comments that a pal's early TV175 had the same painted white mounts.
The example shown certainly makes me change my mind, having been very sceptical, and is another example of needing to keep an open mind when looking at Innocenti's ever changing specifications.
Postby Dimitrios_231 » Sat Feb 06, 2016 3:45 pm
I have worked on a Silver Special,it had white mounts,I thought that they were aftermarket,very intersting.
I don't know if I have any pictures saved on my PC.
Another original Silver Special close to my place.
Dimitrios_231
Postby johnnyXS » Sat Feb 06, 2016 4:21 pm
yes engine mounts on the early LiS150 special (pacemaker) were neuvo white to match the tanks and frame ... its been a well established fact for some time . ;) I have pictures of several including my own.
However I wasn't aware that the TV175 was also fitted with the same white coloured mounts though.
A couple of other odd things about my 64 Italian imported special that I noticed was that it has a 175cc stamped inlet manifold fitted...far as I can tell it is the original equipment . :?
Also there was no rubber gasket /trim fitted under the air scoop on mine either and that is definitely how it left the factory as the fresh paint underneath clearly shows.
johnnyXS
Postby Dimitrios_231 » Sat Feb 06, 2016 4:28 pm
The 175 manifold 19711004 (middle in the pic) is standard for Li150S and TV173 S3 according to the official spares catalogue.
Dimitrios_231
Postby johnnyXS » Sat Feb 06, 2016 4:37 pm
ahhhh that explains it thanks for posting Dimitrios. I had a nagging worry that some previous owner had fitted it .
idon't suppose you have a link to an online parts catalogue for the special do you ?
johnnyXS
Postby Dimitrios_231 » Sat Feb 06, 2016 5:32 pm
Dimitrios_231
Postby Wack » Sat Feb 06, 2016 5:55 pm
When you remove the inlet manifold you can see it is bigger where it meets the cylinder which is also ported larger than an LI 150 , as they're listed as making more power than the standard LI.
Postby johnnyXS » Sat Feb 06, 2016 8:06 pm
thanks Dimitrios thats very informaive cheers.
Wack .....is that all Innocenti did to get an extra HP over a standard Li150 :roll:
I assumed that the cylinder would have been ported or worked on too.
johnnyXS
Postby Wack » Sat Feb 06, 2016 8:46 pm
TBH I've never compared the 2 cylinders side by side but when I rebuilt my Special I only had NOS 125/150 inlet gaskets and had to cut them out as the Special has a more rounded inlet.
Return to Anorak's Corner
