Li 125/150 Special
Strict no chatter
Re: Li 125/150 Special
Postby sherpadean » Sun Aug 24, 2014 9:39 am
Further to my earlier post I also noticed that when I stripped the carb' down there was no gasket between the top & main body - is that a mistake by previous owner or is a gasket not essential?
sherpadean
Postby Meds » Sun Aug 24, 2014 10:23 pm
I believe the 5899-4 will run a little richer than the 5899-5.
It is possible the previous owner jetted it up as it sounds like Innocenti never fully bottomed the 125 Special jetting
Meds
Postby daniel whiteley » Sat Aug 30, 2014 5:23 pm
hi all , im currently restoring my 125 special and unfortunately ive had to purchase some remade panels (supposed to be of the better quality from buzz but ive spent a few days knocking them about with a shrinking hammer and now in the "FULL SKIM" of filler luckily for me im a panel beater and it doesnt cost me ) anyway back to what i was asking , due to the fact they are repo they dont have the holes in them so does anybody do templates for the badge holes ? especially the "lambretta"
many thanks
daniel whiteley
Postby GeneM » Wed Oct 29, 2014 1:27 pm
sherpadean wrote:Further to my earlier post I also noticed that when I stripped the carb' down there was no gasket between the top & main body - is that a mistake by previous owner or is a gasket not essential?
the SH1.18 and SH1.20 did not have a gasket for the slide top cover and the body. that gasket was introduced on the SH2.22 which is bigger. I dont think anyone makes one that would fit a 18 or 20 either...
GeneM
Postby Wack » Mon Nov 10, 2014 10:44 pm
Just stripping the 150 Special motor which hasn't been apart since new by the look of it inside the casing. For something that's done 61000 k the only wear was to the chain and top guide and .5mm on the gear endfloat. The crank seals were rock hard and needs a crank rebuild , top end has a newish Asso 57.8mm piston with thick rings so just a clean up should do. Interestingly the gearbox has the late thick 3rd loose gear but the cluster is drilled for the pressure plate which according to Sticky book it shouldn't? I'll be changing the Dansi flywheel though as it shows movement between the boss and casting. Is it possible to mix a Dansi stator with a Ducati flywheel or will I need a Ducati stator as well? Sorted ,just lathed the centre out on the stator.
Postby Wack » Tue Nov 11, 2014 10:05 pm
Another question I have is after reading various literature ,the Silver was only produced between May and Sept'65 but I keep seeing "Silvers "for sale on '64 plates? Anyone explain?
Postby Wack » Sun Nov 30, 2014 7:40 pm
More interesting facts.
All the wheel nuts and seat bolts are 14 mm headed
The forks have the I logo on the casting and are drilled as per Ser 2 but without the welded lower cable guide
Grease nipples fitted to all cables apart from speedo
The Phillips headlight bulb even has an IGM number.
Postby Meds » Mon Dec 01, 2014 11:01 am
I was told that the 150 Specials only came in silver and gold, the silver ones were later badges as Silver Specials and the name stuck for all specials in silver, hence why you see 64 silver specials.
My 64 special doesn't have the holes for the silver badge but had all the correct bits for that year, that would back up your findings about proper Silver specials not being made until 65.
I don't know about the golden specials.
As for the M8 thread 14mm AF nuts and bolts this is quite common (and use to confuse the hell out of me ) until one of the fitters at work said that full standardisation didn't happen until until mid 60s. Ritch Presley use to sell the M8 14 mm AF nuts for wheel rims.
What's was worse was having a mixture of 13mm and 14mm AF wheel nuts on the one hub.
Meds
Postby Wack » Mon Dec 01, 2014 7:03 pm
It's odd about the wheel nuts as according to Restorations website 14 mm AF nuts were only fitted to Ser 1+2's. I really think that Innocenti just used whatever was in stock at the time and probably had stock rotation so that any older parts were used up before newer items were used?
Postby Mark esq » Mon Dec 08, 2014 8:08 pm
What's the prefered replacent ignition switch for a 65 lis 150 non chrome ring, remade Italian stamped Osam or casa. Im thinking osam.
Mark esq
Postby Wack » Mon Dec 08, 2014 10:05 pm
Mine has an Elesa Torino ignition switch
Postby Mark esq » Mon Dec 08, 2014 10:23 pm
Hi Wack I've not heard of particular switch I'm gonna take out the original switch and have a closer look. Is that your original switch?
Mark esq
Postby Wack » Mon Dec 08, 2014 11:05 pm
I didn't know the switch make and bought an original key based on the number on the barrel. Apparently each manufacturer had a set amount of numbers to work to,so the number on the barrel identifies the maker. I've seen a list somewhere but can't remember where.
Postby Mark esq » Tue Dec 09, 2014 11:54 am
Cheers Wack i'll look into that.
Mark esq
Postby Marty ULC » Tue Dec 09, 2014 12:43 pm
Did the later 125 specials (with clip in buffers and square horncast badge) have clip on panels or handles?
Marty ULC
Postby Wack » Tue Dec 09, 2014 12:49 pm
Not sure if the late models changed to clip ons ,certainly the SX 's did which superceeded the Specials .The only mod was to change from the panel roller wheel to the black plastic block?
Postby Dimitrios_231 » Tue Dec 09, 2014 7:30 pm
How accurate is the info about the frame production numbers?
I have the second 150 Special frame of 65.
I always had the feeling that it was a 64 frame :)
Dimitrios_231
Postby Wack » Tue Dec 09, 2014 10:05 pm
Postby Dimitrios_231 » Tue Dec 09, 2014 10:37 pm
Thank you,
same figures,
my mistake earlier,it is the third not the second 150 Special of 1965.
Dimitrios_231
Postby Wack » Tue Dec 09, 2014 10:56 pm
Third series, non chrome ring I believe.
Return to Anorak's Corner
