by warniep » Tue Jan 23, 2018 12:44 am
I'm fitting a Mugello kit on my GP. What gasket sealant would you recommend to put between the head and cylinder ? Thanks in advance.
warniep
by Jim Rose » Tue Jan 23, 2018 6:35 am
Just use a gasket the machining on these kits is good so as long as it torqued up properly you'll be fine.
Jim Rose
by warniep » Tue Jan 23, 2018 1:27 pm
Thank you very much for you replies, much appreciated
warniep
