gazzar15 wrote:I should have said I bought the scoot in bits....the piston apparently had seized, crank screwed carb in bits etc.Hence the need to buy new parts...was looking today at what is out there and almost had heart failure at some of the prices being asked for engine parts.
Surely there must be some middle ground without stumping up for a £500 plus Mugello?
My belief was I could get a kit , crank ,carb exhaust and electronic ignition system for around 1k?
I had set this figure as a budget...didn't seem unrealistic
ToBoldlyGo wrote:Dickie. Dump the 25mm carb and clubman exhaust. Go for a 20mm and standard exhaust. Perfect set up. And what you lose in power will be negligiable.
gazzar15 wrote:In the grand scheme of things it looks like the RT 95 kit is comparably reasonable money.....what crank would you recommend and would a new standard clutch be up to the task?
Thanks again gents
Thanks again gents
