Ultimate small block kit.
Postby Scooterlam » Wed Oct 25, 2017 7:59 pm
Sort of lost touch with recent developments in the small block world.
Looking for fast tourer. In a s1.
Prefer nicasil over iron
What's about.
Scooterlam
Re: Ultimate small block kit.
Postby HxPaul » Wed Oct 25, 2017 8:07 pm
Postby Scooterlam » Wed Oct 25, 2017 8:29 pm
HxPaul wrote:There you go - viewtopic.php?f=7&t=9118
Sort of wanted a bit more than kit x whoa there or kit y the dogs danglies.
Scooterlam
Postby Delboyli150 » Wed Oct 25, 2017 8:54 pm
Mugello 198,
Delboyli150
Postby Meds » Wed Oct 25, 2017 9:33 pm
Have a look at this thread
viewtopic.php?f=7&t=3546
Corrado gives some good advice
Meds
Postby Scooterlam » Wed Oct 25, 2017 9:50 pm
Thanks Med how did you get on with the RT..
What was it's spec.
I'm quite interested in the ss200 as as a tourer.
Had experience of the Lydenn hill 225 and was shocked how well it behaved under the most extreme circumstances.
Scooterlam
Postby Meds » Wed Oct 25, 2017 10:43 pm
I like mine- easy to ride, pulls well up hills and zips along nicely.
60x110 crank- BGM exhaust, 30 mil carb, just shy of 18 hp.
Can't fault it.
Meds
Postby lozmondo » Thu Oct 26, 2017 2:23 pm
My Rt is similar to meds but with a 62mm crank (not worth the hassle tbh)
in extreme conditions varying from blistering heat, pouring rain, mountain passes, altitude, motorways and country roads it has been faultless. I know everyone has thier favourites but its performance, rideability and fuel consumption are excellent.
lozmondo
Postby corrado » Fri Oct 27, 2017 2:01 am
Wait for the Quattrini 210 kit for small block. Chiselspeed bolted one on with no further tuning and got great bhp and torque figures at low revs, with their own "Tour" exhaust. It needs a 58 x 116 crank and it'll need it's own specific exhaust, of which Chiselspeed is the only supplier at the minute.
Read this .. https://www.facebook.com/Chiselspeed/?h ... OLshIyjtL0
corrado
Postby HxPaul » Fri Oct 27, 2017 9:23 am
But that thread names every small block kit there is.
Postby Scooterlam » Fri Oct 27, 2017 8:22 pm
corrado wrote:Wait for the Quattrini 210 kit for small block. Chiselspeed bolted one on with no further tuning and got great bhp and torque figures at low revs, with their own "Tour" exhaust. It needs a 58 x 116 crank and it'll need it's own specific exhaust, of which Chiselspeed is the only supplier at the minute.
Cheers Corrodo.
That's the sort of thing
I've read so many write ups on new kits they all sort of merge.
Is this the one that the trans match a big block and the studs match a small block so a late Indian or Spanish case required?
Scooterlam
Postby a-teamlambretta » Sat Oct 28, 2017 10:18 am
Looks like it, or some welding up required or go onto a longer rod and use the packer plate to blend the two together?
a-teamlambretta
Postby Scooterlam » Sat Oct 28, 2017 11:30 pm
Looks very interesting Chisel speed didn't have an issue with the gasket face.
Scooterlam
