Problems selecting 4th
Postby Topgearskin » Sun Oct 22, 2017 6:24 pm
So I replaced the worn Indian 150 box I had in my small block with a new Indian 200 gearbox. Shimmed and set up with no significant issues, but I'm finding that there's a pseudo neutral between 3rd and 4th, and 4th doesn't engage well at all.
Anyone else had this? I think I'm going to have to drop the engine again....
Topgearskin
Re: Problems selecting 4th
Postby Knowledge » Sun Oct 22, 2017 9:35 pm
Before you do anything, just check that the you haven’t caught the loose end of the gear cable when fixing the rear shock back on. A trapped cable is easier to rectify than a gear box strip.
Postby Topgearskin » Mon Oct 23, 2017 9:34 am
Thanks Knowledge - I've checked and that's all ok. I think it may be the selector arm as it feels as though its as far back as it can go yet isn't engaging 4th. I'll try moving it a notch to see whether that cures it tonight.
Topgearskin
Postby terryj » Mon Oct 23, 2017 10:01 pm
is the selector arm fouling on anything as you move to 4th
terryj
Postby gaz_powell » Tue Oct 24, 2017 8:05 am
You shouldn't have knocked those API artisans who as we know via Usha that they took their time........Ushas revenge continues.
Take it no debut at Bridlingstan.....
Keep on keema nan "bolly" lad
