Knowledge wrote:I suppose someone ought to mention TS1 225. All day, every day.
Knowledge wrote:Pro-porting big bore, 283/292 - review to follow
Knowledge wrote:It is a newly cast barrel similar in style to the trusty TS1, but with a bore of 76.25mm.
The casing, and it can be a 125/150 casing, has the mouth machined off, and then a CNC new case-mouth welded on to take the big stud spacing. A new head is machined from billet. The cranks are big diameter made to the usual high standard of Harry Barlow
Toot wrote:Breeze Block??
There large aren't they???
Users browsing this forum: Bing [Bot] and 64 guests
