Opinions: Scootopia Clubman on GT186(200) and 30PHBH?
Postby Donnie » Mon Sep 25, 2017 8:41 am
Anyone running this?
Recently rebuilt and run in GT186 with third port behind the reeds and in the casing to match, 60mm crank and overbore piston taking it to 200cc, 30PHBH and a MBGM clubman that decided the tailpipe wanted a divorce! This with less than 1500 miles on it, it's a sad day when a £30 tyre will outlast a £230 supposedly super exhaust.
ImageIMG_1308 by Donnie Canning, on Flickr
So, I hear good things of the Scootopia Clubman exhaust and wondered if anyone out there ran a similar setup and found it ok / good / rubbish / etc ?
Donnie
Re: Opinions: Scootopia Clubman on GT186(200) and 30PHBH?
Postby Scooterdude » Mon Sep 25, 2017 9:01 am
I've no experience with the GT 186 and amidst all the talk over exhaust stubs I doubt I'll be getting one any time soon, but the Scootopia clubmans are great, I've got a BGM clubman on its way hear to have the rattling baffle sorted out if you care to send me your zorst I'll happily reattach your tail pipe, assuming you didn't loose it that is! Fire me a pm if you want.
Scooterdude
Postby Tractorman » Mon Sep 25, 2017 9:22 am
Why not contact the supplier of the exhaust, there should be a warranty period on it.
Postby HxPaul » Mon Sep 25, 2017 10:10 am
I have two scooters,one a series 2 with a Casa 185 top end and the other is a series 3 with a Casa 210 top end,both have Scootopia Ancillotti type clubman exhausts.They run and sound fantastic.
Postby Rich Oswald » Mon Sep 25, 2017 10:57 am
I have one of the very first BGM V1 Clubmans on my S Type, the one people said was loud, and it's quiet and still solid after thousands of miles. I have a V3 one on my J Range which is much louder but only done 500 miles.
Postby missing lynx » Mon Sep 25, 2017 2:04 pm
V3 on your J range I take it it's got a slim style engine shoehorned into it
Postby roli150lam » Mon Sep 25, 2017 3:05 pm
I have a BGM v1was used on mugello 186&198.The baffle are rattling around inside, case and tailpipe are solid tho.Not loud at all imo.
roli150lam
Postby dickie » Mon Sep 25, 2017 3:10 pm
roli150lam wrote:I have a BGM v1was used on mugello 186&198.The baffle are rattling around inside, case and tailpipe are solid tho.Not loud at all imo.
The loose baffle in mine caused it to cut out all of a sudden. Sometimes I could go 5 miles and other times 500m. I'd get it sorted before you get stranded. Presumably it was blocking the exit.
Postby dickie » Mon Sep 25, 2017 3:12 pm
Scooterdude wrote:I've got a BGM clubman on its way hear to have the rattling baffle sorted out.
Aye, it's mine. Thanks
Postby Donnie » Mon Sep 25, 2017 5:56 pm
Aye, I could contact scooter center i guess but wasn't impressed with the initial service I got from them so not sure I hold a lot of hope out. EDIT, email sent but theres no mention of warranties anywhere I can see :-/
I'll bear you in mind though Scooterdude if thats ok? where about are you?
Donnie
Postby gaz_powell » Tue Sep 26, 2017 7:29 am
No experience on a GT, but on a stage 4 200 with 26mm phbh it works great.
Was easy to fit and they have now repositioned the spring lugs.
Comes with chrome stub and bend, well worth the money on all fronts
Postby coaster » Tue Sep 26, 2017 7:54 am
BGM V3 on my GT240, I had to file the down pipe joints a bit as they were a bit oval and the tail pipe needed a whack so that the kickstart missed it but otherwise is was fine for the 2200 miles to Adria and back. But it is loud ;)
Postby roli150lam » Tue Sep 26, 2017 9:04 am
Yes thanks.I had problems with it on the c2c restricting the power tho not cutting out.
roli150lam
Postby Donnie » Tue Sep 26, 2017 2:21 pm
Well, Scooter center have sent me a free return postage label so im going to get it off today and get it shipped tomorrow and see what happens, theyve not expressly said they were replacing it so ill see if they come up with some excuse for not doing so and make them ship the broken one back to me.
Donnie
Postby Donnie » Tue Sep 26, 2017 6:04 pm
OK, moot point now anyway! just discovered this as i took off the exhaust!
ImageIMG_1310 1 by Donnie Canning, on Flickr
Donnie
Postby rossclark » Tue Sep 26, 2017 11:05 pm
Ouch
Postby ULC Soulagent » Wed Sep 27, 2017 5:36 pm
Have bgm V1 on my S2 Bgm rt 196, it originally cracked around the suspect rear but Broady repaired it foc and has been fine ever since. Have the V3 on my special and again the baffles went but replaced under warranty by SCK. Hope u get it sorted Donnie
Postby Donnie » Wed Sep 27, 2017 7:11 pm
cheers mate, sent it to germany today so will await news :-)
Donnie
