Ts1 head
Ts1 head
Postby jonno » Mon Aug 14, 2017 8:36 pm
What is the best head for a TS1 kit.Af are selling a 9.5:1 and an 8:1. Which is best for a touring set up?
jonno
Re: Ts1 head
Postby hullygully » Wed Aug 16, 2017 6:17 pm
9.5 : 1 on my TS230, nice for touring & when you give it some 8-)
Re: Ts1 head
Postby Paulnobodyimportant » Thu Aug 17, 2017 9:26 am
If you are getting a new head for a TS1, consider these mammoth heads from AF, that run cooler. I swapped my TS1 head for one of these. No difference in power, but it does show a true 20% ish drop in running temperatures on my SIP speedo. If you get through to them, then ask what compression ratios these are set at.
http://www.afrayspeed.co.uk/index.php?p ... buteID=HEA
Paulnobodyimportant
Re: Ts1 head
Postby hullygully » Thu Aug 17, 2017 6:23 pm
you can still get the above ratios for their new mamouths :shock:
Re: Ts1 head
Postby Scooterlam » Wed Aug 30, 2017 12:10 pm
hullygully wrote:you can still get the above ratios for their new mamouths :shock:
Or buy Ron Moss who's development this was.
Scooterlam
Re: Ts1 head
Postby hullygully » Wed Aug 30, 2017 6:18 pm
I like Ron but A/F's are cheaper .................. :cry:
