wide rims front and rear
Postby a-teamlambretta » Wed Aug 09, 2017 4:12 pm
any reason why you cant use wide rims on the front aswell as the back ? im sure its been asked before but cant remember the outcome lol
a-teamlambretta
Re: wide rims front and rear
Postby MickYork » Wed Aug 09, 2017 5:01 pm
Had wide rims on mine with 100/90 tyre. Fitted ok but valve is close to catching and not much space with link bolts.
Running wide rims with 350/10 on now as I found the turning when slow a bit heavy.
I have several sets of wide rims and have noticed that some are wider than others......
Postby gaz_powell » Wed Aug 09, 2017 10:29 pm
I've ran wide back and front on my GP for the 11 years - rightly or wrongly its had plenty of use and I can't think of any adverse effects or issues.
I use standard on the SX so have a comparison with same TS1 motor.
Both run 350x10 S1s
G
Postby a-teamlambretta » Thu Aug 10, 2017 11:34 am
thanks for the info. cheers simon
a-teamlambretta
Postby mark1 » Sat Aug 12, 2017 8:24 pm
Wide rims don't fit with my outboard disc brake, it fouled the disc.
mark1
Postby tim_mason » Sat Aug 12, 2017 8:28 pm
[quote="mark1"]Wide rims don't fit with my outboard disc brake, it fouled the disc.[/quote
I had the same issue with fitting wide rims and an outside disc , i just trimmed a bit off the caliper to make it fit ,
tim_mason
Postby gaz_powell » Sun Aug 13, 2017 4:22 pm
Had to take a tiny bit of the corner of the nissin outboard disc caliper
