Goodridge brake lines
Postby gizmo » Sat Jul 15, 2017 6:06 pm
Any recommendations on who makes up goodridge hoses. Need this type as they have the screw in ends and I want to thread it through a hole in headset rather than slotting it
gizmo
Re: Goodridge brake lines
Postby Angry Bloke » Sat Jul 15, 2017 6:54 pm
I usually build my own using the goodridge "build a line " range
That way if you get your measurements wrong you need to buy another hose but not the fixings/ banjo etc
Angry Bloke
Postby gizmo » Sat Jul 15, 2017 9:42 pm
Sounds good. They direct from goodridge
gizmo
Postby Angry Bloke » Sun Jul 16, 2017 8:05 am
Yes you can get them from Goodridge or eBay / web
Angry Bloke
Postby gizmo » Sun Jul 16, 2017 9:17 am
Angry Bloke wrote:Yes you can get them from Goodridge or eBay / web
Cheers Mr Angry :D
gizmo
Postby Knowledge » Sun Jul 16, 2017 10:05 pm
I have been using Venhill stuff from an eBay seller called up-the-shop.
Good products and excellent service.
Don't forget to use YouTube to see how these things bolt together.
Postby LateAgain » Fri Jul 28, 2017 12:31 pm
Lee Chiggy Chambers (Lambretta Upgrades) will make up some hoses to any spec length if you get in touch and not confident about doing your own. He's on FB, or via website.
He can also supply Banjo's and braided hose if you wish to make your own up, especially if you need to thread through a hole as you will require no banjo on one end for threading.
LateAgain
