Delboyli150 wrote:ok had a little play tonight and got no where, At the moment I have left the powerjet alone in case you cannot shut of completely, I changed the needle to a x7 and could not even pull away so changed back to the x4, but a 125mm in and nothing top end after say 3/4 throttle. But a 110 in same no top end, put a 105 in and same then started raining so that was the end of that!
Will ring Camlam tomorrow as opened to make sure if I turn the Powerjet fully clockwise that will shut the powerjet off completely if this is OK will put the x7 with clip on 2nd one down and see what we get!
Can anyone point me in the right direction as regards Instructions? What is the best ones out there as noticed they are all a bit different. My aim is to shut powerjet, install X7, then take out main jet and work on the first 0-1/2 throttle first.
Any advice welcome.
Delboyli150 wrote:Hi Wt1
Will not get in garage tonight rained off!
Just a quick question, hypothetical, even if I cannot get the main jet right surly I would be able to get above 35mph? Asking in case there could be something else wrong which is not letting me get up to speed, as it is a new build.
Feersum Injun wrote:Ah... the dark arts of carb jetting!
There is a good thread on here somewhere that discusses this
Users browsing this forum: Bing [Bot] and 64 guests
