Small end bearing
Small end bearing
Postby jonno » Mon Jun 26, 2017 2:14 pm
What is the Japanese little end bearing (extra wide )that is used on lambrettas,local dealers have run out. 18mm gudgeon pin.
jonno
Re: Small end bearing
Postby Scooterdude » Mon Jun 26, 2017 3:11 pm
Suzuki TS 250 ER.
Scooterdude
Postby jonno » Mon Jun 26, 2017 10:07 pm
TS suzuki has 16mm i/d ?
jonno
Postby Scooterdude » Mon Jun 26, 2017 10:10 pm
jonno wrote:TS suzuki has 16mm i/d ?
The 185 is 16mm 250 18mm
Scooterdude
Postby dscscotty » Mon Jun 26, 2017 10:12 pm
Depends what conrod your using as there are differences in OD size
Postby HxPaul » Tue Jun 27, 2017 9:30 am
MB sell 18mm and 16mm small end bearings https://www.lambrettaspares.com/lambret ... rings.html
Postby Scooterdude » Tue Jun 27, 2017 1:49 pm
Scooterdude
Postby jonno » Tue Jun 27, 2017 1:55 pm
Thanks for the info
jonno
