jonno wrote:I have a steel lined Ts1 with wiseco piston. Just had a rebore and a heat seize lol.What is a good bore/piston clearance? I have 0.09 at the mo with a feeler gauge down the side of the piston as its slid into the bore,skirt first from the head end.
Fast n Furious wrote:jonno wrote:I have a steel lined Ts1 with wiseco piston. Just had a rebore and a heat seize lol.What is a good bore/piston clearance? I have 0.09 at the mo with a feeler gauge down the side of the piston as its slid into the bore,skirt first from the head end.
In a steel line TS1 a bore clearance of 0.04 - 0.05 mm is normal for use with a high silicon cast piston. 0.09mm would be good for a cast iron cylinder.
Fast n Furious wrote:0.04 - 0.05mm for 66 - 70mm pistons with Nicasil plate or steel liner aluminium cylinders and 0.09mm for cast iron cylinders.
But it all depends upon certain other factors as well. Such as the type/quality of piston used and the overall cooling efficiency of the motor.
The cooling efficiency is mostly ignored or overlooked by most engine builders as it can be quite an involved piece of engineering to improve it.
I've seen cowlings that are so bad you would be better off running without any fitted at all. Of course when it goes wrong, its the poor piston that gets the blame and not the lousy cooling system.
Users browsing this forum: Bing [Bot] and 63 guests
