Gearbox layshaft height challenge
Postby Topgearskin » Wed May 17, 2017 7:34 pm
A little knowledge is a dangerous thing.
Having swapped everything from a knackered Indian casing into a good Italian LI casing, I've now discovered a gearbox issue.
When shimming up I've had to use a 2.6mm shim. And although I'm a little over on the gap, the gearbox won't turn once the endplate is torqued up.
Reading the bible ( stickys book) I've discovered that the gears should sit above the layshaft... and typica
Lay with this build, mine don't.
I've been trying to use some LI150 gears. Even when I've bit the bullet and tried the old Indian gp150 oddball gears that came with the bike, the story remains the same.
So now what? Buy a new gearbox? (And miss the chance to use a desirable LI 150 box - or does anyone know which layshaft will remove this problem?
This bike has been a delight, I have to say. I'm running (eventually) a Gori 200, 18x46, 22 scootopia carb and AF clubman,
Topgearskin
Re: Gearbox layshaft height challenge
Postby Knowledge » Wed May 17, 2017 7:51 pm
Have you tried a different layshaft? You seem to have tried variations on everything else.
Postby Topgearskin » Wed May 17, 2017 9:08 pm
Not as yet. I Was hoping that there was a magic secret, like "the layshaft made by ..... are designed to get over this issue" or "use a bigger shim" or something.
Topgearskin
Postby rossclark » Wed May 17, 2017 9:39 pm
A bigger shim won't help. A different layshaft might. It is possible either the shaft or the gears could be worn causing it to sit lower.
I've heard it said that you can apparently put a shim under the stack to raise them a bit.
Postby Wack » Thu May 18, 2017 5:43 pm
The LI box is always on the limit for some reason so to get around it if different layshafts don't help is to machine the area down where the shim fits on the layshaft to end up 0.1 mm lower than the gears.
Postby Strummer10 » Sun May 21, 2017 2:52 pm
We had the same problem on my mates series 4 and whoever shimmed it before hadn't checked it out properly so it ended up with the layshaft biting into the shim and carving out a round slot. Surprisingly it ran for 12 years with this issue.
We played around with different gearboxes onto the layshaft but with no success and had to change it for another 2nd hand layshaft. I suspect it would be a quicker and maybe just as economical fix to buy a new layshaft.
Strummer10
Postby Topgearskin » Sun May 21, 2017 6:16 pm
Thanks everybody. It's certainly been a journey, this one.
Topgearskin
Postby Delboyli150 » Mon May 22, 2017 6:31 pm
Sorry in case you already have done.....but you have put the rear hub on and tighten up...
Delboyli150
Postby corrado » Tue May 30, 2017 12:38 am
Had you used the Li150 gearbox previously or was it new to you? Some "new" Indian Li 150 boxes on the market that suffer with this problem.
corrado
Postby Topgearskin » Tue May 30, 2017 10:47 am
The gearbox and layshaft were in another casing built buy a mate of mine from Manchester. I had ran the casing and gearbox with a mugello a few years back and it was golden. The Indian casing had a GP150 box in and the layshaft wasn't great either....
Topgearskin
Postby Adam_Winstone » Wed May 31, 2017 10:22 pm
Regardless of the shimming, this isn't just a case of the very common issue of endplate locking Christmas tree until the clutch centre nut is done up to pull the Xmas tree fully home into the endplate bearing is it? It is very normal (more often than not) for the gearbox to lock up when the endplate is fitted. Then fit the clutch centre and nut so that it pulls the Xmas tree home and the gearbox becomes free, then remove clutch nut and centre and tighten the 6 endplate nuts again.
Whilst the shimming issue is annoying, I imagine that there are many motors out there running perfectly reliably with the same issue.
Good luck.
Postby gaz_powell » Sun Jun 11, 2017 6:31 pm
TGS did you get this sorted ???
Postby Topgearskin » Mon Jun 12, 2017 1:49 pm
I think so
I replaced the gearbox with a new SIL GP200. There is now about 1mm gap. This appears to be fine.
Topgearskin
